option batch on/continue
plois00
What is the difference between 'option batch on' and 'option batch continue'?
'option batch on' does not abort the process in case of error.
So what is more with using 'option batch continue'?
Please explain.
Thanks,
PL
Re: option batch on/continue
option batch on does abort the single command in case of failure, although it continues with following command. option batch continue does not abort even the failing command.
