Synchronising / Searching
FlyingEagle
hi,
there's a function to synchronise a local directory with a remote dir ... why only in this way?
with other words, it would be nice to sync a remote dir with an local dir to keep the local dir up to date.
is there a way to make a function for searching files remote?
a recursive function for search couldn't be the problem - or?
regards
fly
Re: Synchronising / Searching
automaticallz, not manualy!
regards II
flz
Synchronization works from remote to local also. Keep dir up to date is different function, which cannot be implemented from remote to local.
It is on TODO list.
cmpcmp
SYNCHRONIZING -time stamp of directory
I use scp 3.8.2
When I synchronize local target with remote source, the files have correct time stamps, but the local directories all have current time (different from time on remote).
I would like to have the ability to copy the time stamp of directories too.
