Problems using WinSCP with C shell in Solaris
garmm6
Albany NY
I'm attempting use WinSCP on a server in which my default shell is the c shell(/bin/csh). I can connect without a problem. When I attempt to copy files I get the error: "Host hasn't answered for 15 seconds....Abort or Retry" Retry doesn't work, just returns with the same message. I then changed the shell on the shell tab from default to /bin/ksh, as I read somewhere else on this site. It didn't work, same results. If I change my default shell on the server to /bin/ksh and set the shell back to default everything works just fine. The only thing is I want to use the C shell and don't want to make my users change. Is there a way?
Thanks for any assistance!!
_________________
Gary Rivenburg
Computer Systems Programmer
NYS Office of Real Property Services
Re: Problems using WinSCP with C shell in Solaris
C shell is not supported. I can't think of any solution for you now. I'm sorry.
