Changing group and owner with SFTP
arie
I'm using WinSCP 4.0 and I'm trying to change ownership of some files on my own webserver.
I log in with SFTP but when I go to the properties, the options are grey.
I red that I must use SFTP-4 for changing the ownership but when I look at the Server and Protocol information I see that I now use SFTP-3.
How can I install SFTP-4 in WinSCP or can I change something on my Apache?
Kind regards,
Arie
Re: Changing group and owner with SFTP
WinSCP supports SFTP-4. Also this has nothing to do with Apache. It is about your SSH/SFTP server. I'm afraid that you are using OpenSSH and there's no update for OpenSSH to SFTP-4.
Hi Prikryl,
I'm using OpenSSH so that can be the problem.
Do you know which app I better can use with SFTP-4?
Kind Regards,
Arie
