Connection...unexpectedly closed. ...command exit status 1.
hawstom
USA
I added this to an old thread, but it wasn't immediately evident I had added a question.
I discovered WinSCP 4.0.0 Beta a couple of weeks ago and I love editing remotely using SCP and Notepad++!
I have an account at Hostmonster I am using it for. And I have an account at JaguarPC I can connect to with it.
But...
I have an account at JaguarPC where I cannot connect using SCP. Can you help me connect?
-I can connect using FTP (but editing and saving doesn't seem to work in FTP mode).
-JaguarPC tech support can connect to the account using WinSCP 3.7.6 or 4.0.0 beta and SCP after renaming .bashrc and .bash_profile
-I tried both version 4.0.0 Beta and 3.8.2 and can't connect to this one account from home or the office.
Here is a typical log:
. 2007-05-15 15:42:58.328 --------------------------------------------------------------------------
. 2007-05-15 15:42:58.328 WinSCP Version 4.0.0 (Build 342) (OS 5.1.2600 Service Pack 2)
. 2007-05-15 15:42:58.328 Login time: Tuesday, May 15, 2007 3:42:58 PM
. 2007-05-15 15:42:58.328 Session name: jconstru@constructionnotesmanager.com
. 2007-05-15 15:42:58.328 Host name: constructionnotesmanager.com (Port: 22)
. 2007-05-15 15:42:58.328 User name: jconstru (Password: Yes, Key file: No)
. 2007-05-15 15:42:58.328 Tunnel: No
. 2007-05-15 15:42:58.328 Transfer Protocol: SCP
. 2007-05-15 15:42:58.328 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-05-15 15:42:58.328 Proxy: none
. 2007-05-15 15:42:58.328 SSH protocol version: 2; Compression: No
. 2007-05-15 15:42:58.328 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-05-15 15:42:58.328 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-05-15 15:42:58.328 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-05-15 15:42:58.328 SFTP Bugs: -,-,-
. 2007-05-15 15:42:58.328 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-05-15 15:42:58.328 Shell: default, EOL: 0
. 2007-05-15 15:42:58.328 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-05-15 15:42:58.328 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-05-15 15:42:58.328 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-05-15 15:42:58.328 Cache directory changes: Yes, Permanent: Yes
. 2007-05-15 15:42:58.328 DST mode: 1
. 2007-05-15 15:42:58.343 Looking up host "constructionnotesmanager.com"
. 2007-05-15 15:42:58.734 Connecting to 207.210.81.210 port 22
. 2007-05-15 15:42:59.218 Server version: SSH-1.99-OpenSSH_3.9p1
. 2007-05-15 15:42:59.218 We claim version: SSH-2.0-WinSCP_release_4.0
. 2007-05-15 15:42:59.218 Using SSH protocol version 2
. 2007-05-15 15:42:59.343 Doing Diffie-Hellman group exchange
. 2007-05-15 15:42:59.609 Doing Diffie-Hellman key exchange
. 2007-05-15 15:43:00.031 Host key fingerprint is:
. 2007-05-15 15:43:00.031 ssh-rsa 1024 c9:5d:66:b1:da:35:5f:aa:d2:7f:62:14:be:c0:b0:e7
. 2007-05-15 15:43:00.031 Initialised AES-256 client->server encryption
. 2007-05-15 15:43:00.031 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-05-15 15:43:00.031 Initialised AES-256 server->client encryption
. 2007-05-15 15:43:00.031 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-05-15 15:43:00.296 Using username "jconstru".
. 2007-05-15 15:43:00.406 Session password prompt (jconstru@constructionnotesmanager.com's password: )
. 2007-05-15 15:43:00.406 Using stored password.
. 2007-05-15 15:43:00.406 Sent password
. 2007-05-15 15:43:00.531 Access granted
. 2007-05-15 15:43:00.640 Opened channel for session
. 2007-05-15 15:43:00.750 Started a shell/command
. 2007-05-15 15:43:00.750 --------------------------------------------------------------------------
. 2007-05-15 15:43:00.750 Using SCP protocol.
. 2007-05-15 15:43:00.750 Doing startup conversation with host.
. 2007-05-15 15:43:00.750 Skipping host startup message (if any).
> 2007-05-15 15:43:00.750 echo "WinSCP: this is end-of-file:0"
. 2007-05-15 15:43:01.984 Server sent command exit status 1
. 2007-05-15 15:43:01.984 All channels closed. Disconnecting
. 2007-05-15 15:43:01.984 Server closed network connection
* 2007-05-15 15:43:02.015 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 1.
* 2007-05-15 15:43:02.015 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Another:
! 2007-05-16 14:44:22.375 Using username "jconstru".
. 2007-05-16 14:44:22.484 Session password prompt (jconstru@constructionnotesmanager.com's password: )
. 2007-05-16 14:44:22.484 Using stored password.
. 2007-05-16 14:44:22.484 Sent password
. 2007-05-16 14:44:22.609 Access granted
. 2007-05-16 14:44:22.718 Opened channel for session
. 2007-05-16 14:44:22.828 Started a shell/command
. 2007-05-16 14:44:22.828 --------------------------------------------------------------------------
. 2007-05-16 14:44:22.828 Using SCP protocol.
. 2007-05-16 14:44:22.828 Doing startup conversation with host.
. 2007-05-16 14:44:22.828 Skipping host startup message (if any).
> 2007-05-16 14:44:22.828 echo "WinSCP: this is end-of-file:0"
. 2007-05-16 14:44:24.078 Server sent command exit status 1
. 2007-05-16 14:44:24.078 All channels closed. Disconnecting
. 2007-05-16 14:44:24.078 Server closed network connection
* 2007-05-16 14:44:24.078 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 1.
* 2007-05-16 14:44:24.078 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Can you help me?
Re: Connection...unexpectedly closed. ...command exit status 1.
First I would recommend you to try SFTP. Have you tried that? You may also check the server's log file to see why the server closes connection.
