moving remote directories on mountpoints
mwtoews
I'm having difficulty moving remote directories on a remote server with WinSCP versions 3.8.2 and (beta) 4. I have no problems moving directories within the home directory, however I receive:
Error code: 4
Error message from server: Failure
Request code: 18
when I try to move to a mount point '/vault' on the server. The mount point I believe is in a different physical location, and I looked at the /etc/fstab file to read:
gridstore:/vault /vault nfs rw,hard,bg,intr,nfsvers=3,tcp,rsize=32768,wsize=32768 0 0
I can move the 'moveme' directory remotely using a terminal, for example
mv /home/user/moveme /vault/user/
but not with WinSCP. I'm unfamiliar with the SCP protocol, but is what I request impossible? Is this a bug? Thanks!
Re: moving remote directories on mountpoints
OpenSSH SFTP server does not allow moving files across filesystems. Note that you use SFTP, not SCP. However it would probably neither be possible with SCP.
mwtoews
Thanks, that worked! I was using SFTP before, but I now tried switched my login settings to SCP, and now I can move stuff between the NFS mounts!
