[Suggestion] Read Windows FTP/Internet shortcuts
Kenzeitak
Greetings!
Windows .URL files which Internet Explorer and Mozilla creates use a simple XML/INI like file structure that are easy to open.
Heres an example: mylink.url
[InternetShortcut]
URL=ftp://username:password@ftp.host.net/
Modified=60B4FE785E44C501F2
IconIndex=47
IconFile=C:\WINDOWS\system32\SHELL32.dll
Its not any good security but since many windows applications use this file syntax i would like to see it implemented!
Keep up the good work, this FTP client is great! :wink:
Kenzeitak
I use about 50 different shortcuts... Its a time saver for those who have used windows built in FTP. Not that its recommended but it works somewhat.
Keep up the good work!
Regards
Sorry, I still do not understand what should WinSCP do with the shortcuts.
