Turning off "Copy" dialog box when uploading
abrooke
Toronto
Is there any way to turn off the 'Copy' dialog box that appears when you press F5 to upload files? I've enabled all the 'auto' features I could find, but this dialog box still appears. I would basically like to upload files using my keyboard without being prompted further - similar to CuteFTP.
Thanks!
jig
how do I get the copy dialog back?
I choose not to show the copy dialog when pressing F5, I want change the preference, how do I go about it please?
Re: how do I get the copy dialog back?
Please read documentation. If that does not help, come back.
kevej
how do I get the copy dialog back for drag and drop funciton
The copy dialog box appears perfectly when I press F5. However, when a drag and drop is performed the copy dialog box disaapears.
Re: how do I get the copy dialog back for drag and drop funciton
Dissappears or does not appear at all?
If it does not appear at all, do you have Drag & drop operations selected on https://winscp.net/eng/docs/ui_pref_environment ?
The dialog box appears for an very quick instant and then disappears.
And what happens then? Is the main window responsive? Does file transfer start?
