4.0 beta - "Remember session password and pass it to PuTTY"
ernolf
Germany
Settings -> Integration -> "Remember session password and pass it to PuTTY" does not work. In 3.8.2 it did.
chears,
ernolf
Re: When will this be fixed?
It is solved already. The fix will be part of the next release, within one or two weeks.
Michal
password is still not passed to putty
I had to return to old good 3.8.2. If this is already resolved, where can I download it?
One more question: Both, v4 and 3.8.2. have the same bug - there is a difference when you push Alt+F6 and when you do it via "Files > Edit link". Is this fixed as well?
Thanks.
Michal
Re: password is still not passed to putty
Solved, but not released yet :-)
It was intended that it should do something bit different. But I see that it does not what was intended. Thanks :-)
