Commande line
bmfouad
Commande line
I try to execute this commande, but it thase'n work
"C:\Program Files\WinSCP\WinSCP.com" intraftp synchronize remote c:\test /
i want to synchronize the local dir "c:\test" with the remote directory.
Re: Commande line
Correct command is probably:
"C:\Program Files\WinSCP\WinSCP.com" intraftp /command "synchronize remote c:\test /" "exit"
Re: Commande line
Thank you very much, it works.
