su after a connection
cruiser
I'd rather not store su passwords, but I do like to keep profiles for WinSCP.
Is there a way to su after making a connection?
( mainly I need to chown or attrib files ):?:
thx
mike
Reply with quote E-mail
Re: su after a connection
You cannot execute 'su' in WinSCP session. At least most of the servers refuse to execute 'su' for session with not allocated PTY. But you may try it from 'Console' window.
su requires user input ( the password! ), how do you get around that? Or am I missing something obvious?
mike
IMHO you cannot get around that. 'su' needs PTY for security reasons. So to say: you need to be human to run 'su', and WinSCP is not a human :-) For example you cannot create file with your password and redirect it as input to 'su'. It will detect that. If you find some solution, let me know, I'm interested.
dasr
How about using sudo or super? That wouldn't need access to tty (at least when configured to not ask password).
Thanks for hint. I haven't known about the 'sudo' and 'super'. I'll think about utilizing them.
