Problems after editing files
Zap
winscp (V 4.0.0.0 Build 342) on WinXP Pro SP2
When I have edited a file in winscp, I get prompted for login and pwd which is all fine but then winscp hangs like this (<invalid hyperlink removed by admin>)
The file gets updated and uploaded as it should but I have to use task manager in order to kill winscp.
Otherwise I LOVE this program!
Thanks A Lot Martin!
Re: Problems after editing files
What if you specify username and password on login dialog and check option "remember password for brackground transfers"? Would it prevent winscp hanging?
