WinSCP v 3.8.2 Build 330
markus
I try to use WinSCP v 3.8.2 Build 330 under Windows 2003 Server with SP2.
When I start the program, every time I get an error message "ungültiger Zugriff auf Speicher".
Re: WinSCP v 3.8.2 Build 330
This will be fixed with the next release. Workaround is to use english-only version or to add WinSCP on exception list of DEP (data execution protection).
misi
I'm using version 4.1.8 and have the same problem. Is there a solution?
Also with German version? Does English one work? What is your OS? (version of Windows, 32/64 bits, ...)
Yes, i'm using the german version. But even the english version shows this message, but then in english of course. I'm using Windows XP Pro, SP2, 32 Bits.
Does it happen even if you delete the german translation file?
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? You will find my address (if you log in) in my forum profile. Please include link back to this topic. Thanks.
