Using windows default instead of internal editor
Hugo
It would be nice (for me) if double-clicking on a file in the local window would function like it does in Explorer (i.e. open the file in the associated program). For example, PDF and PS files opening in the internal editor was unexpected :)
gerald
you can do this in the preference box:
preferences-->Environnement-->Panneaux (in french)
In english (i suppose)
Environment-->Panels
:wink:
Hugo
Thanks! It took me a short while to find it, since there are two preference windows which both have an "Environment" option -- naturally, I looked at the wrong one.
Hugo
