No root login
shahidr100
No root login
Hi
I frequently need to download and upload files to and from a Linux Server.
Root login is disabled at Linux server so I have to login as a normal user and then go to super user to come to root. After that I do a WinSCP session and transfer files. This whole process is bit cumbersome.
Isnt there any method in WinSCP through which I can do it at one go and I do not have to log in to linux server first to allow root login and then login thru winscp.
Thank you
shahidr100
Re: No root login
How do you allow WinSCP to login as root?
To allow root login to WinSCP, first i login to the linux server as a normal user using putty. Then I do a super user. Edit the sshd_config file to allow root login. Then I restart the sshd daemon. Then i log off from Putty. Now I log in as root using Winscp.
Shahid
shahidr100
Re: No root login
Please read FAQ.
Thanks for your reply, however, the method specified in faq is not working. I tried it couple of times. I am allowed to sudo from command line easily.
Please help.
shahidr100
Re: No root login
shahidr100 wrote:
Please read FAQ.
Please help.
Its working now. Actually I didnt select "SCP" as a protocol that is why it was not working.
Thank you so much.
Re: No root login
I logged in to my internet server with putty and did the super user thing, but when I start WinSPC on my client I still have no permissions. How did you manage to get the permissions ?
Regards,
Frank
shahidr100 wrote:
Hi
Thank you
Re: No root login
Have you read the mentioned FAQ?
Re: No root login
I configured my system exactly according to your suggestions prikryl, spent hours, but my connection still times out when I get to 'sudo su'. I am a programmer/developer and admin on several servers, but could not figure this out. Would you mind, just for us lowly mortals, kindly put together a DETAILED step-by-step instruction that is more specific than the very vague FAQ you always refer to?
THANKS!!!
Zsolt
Re: No root login
Sorry, I'm not an unix expert. I do not know how to help you further. Maybe someone else...
Re: No root login
Ok, so you enter the shell command in WinSCP, make sure that you can 'sudo su' without being prompted for a root password, you start a WinSCP session by logging in through a non-priviliged account... and then what?
Thanks.
Zsolt
Re: No root login
Nothing. That's it. You should be logged in as a root.
