Netspy
Vista problem
I use Windows Vista Ultimate x64 and WinSCP with NC user interface. If I select files with the Ins key, the F5 key doesn't work. If I select the files with mouse or Shift+Cursor, F5 works fine.
Site Admin -
- 43,055
- Prague, Czechia
Re: Vista problem
Do the files get highlighted with Ins? Does other method of copy work (buttons, menu, etc.)?I use Windows Vista Ultimate x64 and WinSCP with NC user interface. If I select files with the Ins key, the F5 key doesn't work. If I select the files with mouse or Shift+Cursor, F5 works fine.
- Guest
Re: Vista problem
Yes.Do the files get highlighted with Ins?
Yes. Only the F5 key doesn't work after Ins.Does other method of copy work (buttons, menu, etc.)?
Netspy
Re: Vista problem
Sorry, my mistake. Other methods of copy doesn't work. The copy button and menu item are gray.Does other method of copy work (buttons, menu, etc.)?
Site Admin -
Re: Vista problem
What if you select some files with Ins and then select another file with mouse (while holdind ctrl)? You Copy enable? And if you then deselect (again with mouse) that one file (leaving selected only files previously select with Ins), would the Copy stay enabled?
Netspy
Re: Vista problem
- I select 3 files with Ins: WinSCP say 3 of 18 files selected but [F5 Copy] is disabledWhat if you select some files with Ins and then select another file with mouse (while holdind ctrl)? You Copy enable? And if you then deselect (again with mouse) that one file (leaving selected only files previously select with Ins), would the Copy stay enabled?
- I select 2 files with Ctrl+Mouse: 5 of 18 files selected, [F5 Copy] is enabled (if I copy the files, all 5 files will transfered)
- I unselect one of the file with Ctrl+Mouse: 4 of 18 files selected, [F5 Copy] is enabled
- I unselect another file with Ctrl+Mouse: 3 of 18 files selected, [F5 Copy] is disabled
While testing, I see another problem. No matter how I select the files, if I move the file focus with cursor up or down, F5, F6 and F8 will be disabled.
Site Admin -
Re: Vista problem
Can you mail me your email address, so I can send you back a debug version?
Netspy
netspy (at) arcor (dot) de
Site Admin -
Thanks. I'll contact you in few days.netspy (at) arcor (dot) de
Vadim Makarov
I'm having the same problem. I've just upgraded from 4.0.2 to 4.0.3, but this hasn't fixed this bug.
If you want to get details, test a debug version, etc., you can contact me at makarov@vad1.com
Site Admin -
- 43,055
- Prague, Czechia
I have sent you an email.I'm having the same problem. I've just upgraded from 4.0.2 to 4.0.3, but this hasn't fixed this bug.
If you want to get details, test a debug version, etc., you can contact me at ...
Site Admin -
Can anyone else, who is having this problem, contact me on my email address?
