- TBCI3
- 1
IGNORE PERMISSIONS
When we are trying to transfer files to the server, we get an abort message (but not all the time). The message is "Upload of file (file name) was successful, but error occurred while setting the permissions and/or timestamp. If problem persists, turn on ignore permissions option. We then turn on the ignore permissions option and more files transfer, but then the same abort message occurs again on another file. What is happening and what do we do to stop it? The example transfer was 48 files for a total of 3620KB.
Site Admin -
- 42,786
- Prague, Czechia
Re: IGNORE PERMISSIONS
Do you transfer the files one by one or in batch?
- Guest
I'm having the exact same problem. In the Preferences > Transfer > Upload Options I told WinSCP to ignore permission errors. Now it does ignore them when using the GUI app. But when running a batch I still get the error for most of my files. I've even gone into Preferences > Transfer > Presets > Upload Options settings for binary and ascii and changed the "Ignore permission errors" to true. Still, in batch mode I see permission errors.
Any way to disable this?
Site Admin -
- 42,786
- Prague, Czechia
What version of WinSCP are you using? Do you run the GUI and script under the same local (Windows) account?I'm having the exact same problem. In the Preferences > Transfer > Upload Options I told WinSCP to ignore permission errors. Now it does ignore them when using the GUI app. But when running a batch I still get the error for most of my files. I've even gone into Preferences > Transfer > Presets > Upload Options settings for binary and ascii and changed the "Ignore permission errors" to true. Still, in batch mode I see permission errors.
- STA05
- 7
Hi prikryl
I also having the same problem even after i've done all the "Ignore permission errors" setting. I've coded my program to resend the same file until it success.
On the 2nd/3rd times resend, it did not have the "Ignore permission errors" and uploaded successful.
Any idea what might causing the failure on the 1st place?
1. Currently, i'm using 3.8.2 version and running on script.
2. Yes, GUI and script running under same account.
Any suggestions are much appreciated.Thank you.
Site Admin -
- 42,786
- Prague, Czechia
I'm sorry I do not understand your problem. Can you try to describe it again?Hi prikryl
- STA05
- 7
Sorry, my problem is exactly same as user TCBI3: trying to upload files to the server, and get an abort message (but not on all the files).
I have turn on the ignore permissions option but the error still happened on the same file again. I've coded my program to resend the file if error happened. When the program try to resend the same file on the 2nd or 3rd times, it uploaded successful and did not hit any errors. So, any suggestion on why this happen?
Let me know if you need more information.
Thank you for your time.
Site Admin -
- 42,786
- Prague, Czechia
Please post a log file showing failure with ignore permissions on and preserve timestamp off.Sorry, my problem is exactly same as user TCBI3: trying to upload files to the server, and get an abort message (but not on all the files).
- STA05
- 7
Below is the log file
batch abort
confirm off
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "pg".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] pg@10.10.10.10
/cygdrive/d/ftp/incoming/pg
D:\Dragon\ImportManifest\AckTemp
manifest_info_ANZ_0153263 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153268 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153269 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153271 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153316 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153317 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153318 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153319 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153320 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153321 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153322 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153323 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153324 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153325 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153326 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153327 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153328 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153329 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153331 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153332 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153333 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153334 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153335 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153336 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153337 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153338 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153339 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153340 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153341 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153342 | 0 kB | 0.0 kB/s | ascii | 0%
manifest_info_ANZ_0153343 | 0 kB | 0.0 kB/s | ascii | 0%
Upload of file 'manifest_info_ANZ_0153343_ACK.xml' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 9
For your information, the preserve timestamp setting is ON due to i need the original timestamp. Is this the cause of the error?
Thank you.
batch abort
confirm off
Initialisation...
Authenticating...
Authenticated.
Session started.
Error code: 2
Request code: 9
Thank you.
Site Admin -
Can be. If you are not an owner of the file, you may not have permissions to change the file timestamp.For your information, the preserve timestamp setting is ON due to i need the original timestamp. Is this the cause of the error?
- Guest
Hi Prikryl
I think the posibility of timestamp causing the error is quite low because
1. From the log file i posted earlier shown that out of 20 on same type of file, only 1 or 2 files encounter this error message.
2. For the same file (file failed earlier), on the second or third time resend it upload successfully.
THanks.
Site Admin -
- 42,786
- Prague, Czechia
OK, so please post a log file (not screen dump).I think the posibility of timestamp causing the error is quite low because
- Guest
Sorry, misunderstood on posting log file earlier.
Connection start on 2007-03-07 16:30:49.573 with all files uploaded successfully. Please use manifest_info_ANZ_0162800_ACK.xml for reference.
Thanks.
. 2007-03-07 16:02:01.620 --------------------------------------------------------------------------
. 2007-03-07 16:02:01.620 WinSCP Version 3.8.2 (Build 330) (OS 5.0.2195 Service Pack 4)
. 2007-03-07 16:02:01.620 Login time: Wednesday, March 07, 2007 4:02:01 PM
. 2007-03-07 16:02:01.620 Session name: USRpg@10.10.10.10
. 2007-03-07 16:02:01.620 Host name: 10.10.10.10 (Port: 22)
. 2007-03-07 16:02:01.620 User name: USRpg (Password: Yes, Key file: No)
. 2007-03-07 16:02:01.620 Transfer Protocol: SFTP (SCP)
. 2007-03-07 16:02:01.636 SSH protocol version: 2; Compression: No
. 2007-03-07 16:02:01.636 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-03-07 16:02:01.636 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-03-07 16:02:01.636 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-03-07 16:02:01.636 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-03-07 16:02:01.636 SFTP Bugs: -,-,-
. 2007-03-07 16:02:01.636 Proxy: none
. 2007-03-07 16:02:01.636 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-03-07 16:02:01.636 Shell: default, EOL: 0
. 2007-03-07 16:02:01.636 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-03-07 16:02:01.636 Cache directory changes: Yes, Permanent: Yes
. 2007-03-07 16:02:01.636 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-03-07 16:02:01.636 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-03-07 16:02:01.636 --------------------------------------------------------------------------
. 2007-03-07 16:02:01.636 Looking up host "10.10.10.10"
. 2007-03-07 16:02:01.636 Connecting to 10.10.10.10 port 22
. 2007-03-07 16:02:01.777 Server version: SSH-2.0-OpenSSH_4.3
. 2007-03-07 16:02:01.777 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-03-07 16:02:01.777 Using SSH protocol version 2
. 2007-03-07 16:02:01.870 Doing Diffie-Hellman group exchange
. 2007-03-07 16:02:02.198 Doing Diffie-Hellman key exchange
. 2007-03-07 16:02:02.683 Host key fingerprint is:
. 2007-03-07 16:02:02.683 ssh-rsa 2048 79:25:e4:50:76:62:a8:b9:95:56:7a:51:3a:48:a7:a9
. 2007-03-07 16:02:02.683 Initialised AES-256 client->server encryption
. 2007-03-07 16:02:02.683 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-03-07 16:02:02.683 Initialised AES-256 server->client encryption
. 2007-03-07 16:02:02.683 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-03-07 16:02:02.933 Using username "USRpg".
. 2007-03-07 16:02:03.058 Keyboard-interactive authentication refused
. 2007-03-07 16:02:03.058 Session password prompt (USRpg@10.10.10.10's password: )
. 2007-03-07 16:02:03.058 Using stored password.
! 2007-03-07 16:02:03.058 Authenticating with pre-entered password.
. 2007-03-07 16:02:03.058 Sent password
. 2007-03-07 16:02:03.105 Access granted
. 2007-03-07 16:02:03.198 Opened channel for session
. 2007-03-07 16:02:03.277 Started a shell/command
. 2007-03-07 16:02:03.277 --------------------------------------------------------------------------
. 2007-03-07 16:02:03.277 Using SFTP protocol.
. 2007-03-07 16:02:03.277 Doing startup conversation with host.
> 2007-03-07 16:02:03.277 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2007-03-07 16:02:03.527 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2007-03-07 16:02:03.527 SFTP version 3 negotiated.
. 2007-03-07 16:02:03.527 We believe the server has signed timestamps bug
. 2007-03-07 16:02:03.527 We will use UTF-8 strings for status messages only
. 2007-03-07 16:02:03.527 Limiting packet size to OpenSSH limit of 262148 bytes
. 2007-03-07 16:02:03.527 Getting current directory name.
. 2007-03-07 16:02:03.527 Getting real path for '.'
> 2007-03-07 16:02:03.527 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2007-03-07 16:02:03.620 Type: SSH_FXP_NAME, Size: 43, Number: 16
. 2007-03-07 16:02:03.620 Real path is '/home/USRpg'
. 2007-03-07 16:02:03.620 Startup conversation with host finished.
. 2007-03-07 16:02:03.620 Cached directory change via "PG-Incoming" to "/cygdrive/d/ftp/incoming/pg".
. 2007-03-07 16:02:03.620 Getting current directory name.
. 2007-03-07 16:02:03.620 Copying 22 files/directories to remote directory "/cygdrive/d/ftp/incoming/pg"
. 2007-03-07 16:02:03.620 PrTime: Yes; PrRO: Yes; Rght: rwxrwxrwx; PrR: Yes (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2007-03-07 16:02:03.620 TM: M; ClAr: No; ExclM(No):
. 2007-03-07 16:02:03.620 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-03-07 16:02:03.620 File: "manifest_info_ANZ_0162775_ACK.xml"
. 2007-03-07 16:02:03.620 Copying "manifest_info_ANZ_0162775_ACK.xml" to remote directory started.
. 2007-03-07 16:02:03.636 Ascii transfer mode selected.
. 2007-03-07 16:02:03.636 Opening remote file.
> 2007-03-07 16:02:03.636 Type: SSH_FXP_OPEN, Size: 86, Number: 259
< 2007-03-07 16:02:03.730 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2007-03-07 16:02:03.730 Type: SSH_FXP_CLOSE, Size: 13, Number: 772
> 2007-03-07 16:02:03.730 Type: SSH_FXP_SETSTAT, Size: 86, Number: 521
< 2007-03-07 16:02:03.823 Type: SSH_FXP_STATUS, Size: 24, Number: 772
< 2007-03-07 16:02:03.823 Status/error code: 0
< 2007-03-07 16:02:03.933 Type: SSH_FXP_STATUS, Size: 24, Number: 521
< 2007-03-07 16:02:03.933 Status/error code: 0
. 2007-03-07 16:02:03.933 File: "manifest_info_ANZ_0162790_ACK.xml"
. 2007-03-07 16:02:03.933 Copying "manifest_info_ANZ_0162790_ACK.xml" to remote directory started.
. 2007-03-07 16:02:03.933 Ascii transfer mode selected.
. 2007-03-07 16:02:03.933 Opening remote file.
> 2007-03-07 16:02:03.933 Type: SSH_FXP_OPEN, Size: 86, Number: 1027
< 2007-03-07 16:02:04.042 Type: SSH_FXP_HANDLE, Size: 13, Number: 1027
> 2007-03-07 16:02:04.042 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
> 2007-03-07 16:02:04.042 Type: SSH_FXP_SETSTAT, Size: 86, Number: 1289
< 2007-03-07 16:02:04.136 Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< 2007-03-07 16:02:04.136 Status/error code: 0
< 2007-03-07 16:02:04.245 Type: SSH_FXP_STATUS, Size: 24, Number: 1289
< 2007-03-07 16:02:04.245 Status/error code: 0
. 2007-03-07 16:02:04.245 File: "manifest_info_ANZ_0162791_ACK.xml"
. 2007-03-07 16:02:04.245 Copying "manifest_info_ANZ_0162791_ACK.xml" to remote directory started.
. 2007-03-07 16:02:04.245 Ascii transfer mode selected.
. 2007-03-07 16:02:04.245 Opening remote file.
> 2007-03-07 16:02:04.245 Type: SSH_FXP_OPEN, Size: 86, Number: 1795
< 2007-03-07 16:02:04.355 Type: SSH_FXP_HANDLE, Size: 13, Number: 1795
> 2007-03-07 16:02:04.355 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
> 2007-03-07 16:02:04.355 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2057
< 2007-03-07 16:02:04.448 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
< 2007-03-07 16:02:04.448 Status/error code: 0
< 2007-03-07 16:02:04.558 Type: SSH_FXP_STATUS, Size: 24, Number: 2057
< 2007-03-07 16:02:04.558 Status/error code: 0
. 2007-03-07 16:02:04.558 File: "manifest_info_ANZ_0162792_ACK.xml"
. 2007-03-07 16:02:04.558 Copying "manifest_info_ANZ_0162792_ACK.xml" to remote directory started.
. 2007-03-07 16:02:04.558 Ascii transfer mode selected.
. 2007-03-07 16:02:04.558 Opening remote file.
> 2007-03-07 16:02:04.558 Type: SSH_FXP_OPEN, Size: 86, Number: 2563
< 2007-03-07 16:02:04.667 Type: SSH_FXP_HANDLE, Size: 13, Number: 2563
> 2007-03-07 16:02:04.667 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2007-03-07 16:02:04.667 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2825
< 2007-03-07 16:02:04.761 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
< 2007-03-07 16:02:04.761 Status/error code: 0
< 2007-03-07 16:02:04.870 Type: SSH_FXP_STATUS, Size: 24, Number: 2825
< 2007-03-07 16:02:04.870 Status/error code: 0
. 2007-03-07 16:02:04.870 File: "manifest_info_ANZ_0162793_ACK.xml"
. 2007-03-07 16:02:04.870 Copying "manifest_info_ANZ_0162793_ACK.xml" to remote directory started.
. 2007-03-07 16:02:04.870 Ascii transfer mode selected.
. 2007-03-07 16:02:04.870 Opening remote file.
> 2007-03-07 16:02:04.870 Type: SSH_FXP_OPEN, Size: 86, Number: 3331
< 2007-03-07 16:02:04.964 Type: SSH_FXP_HANDLE, Size: 13, Number: 3331
> 2007-03-07 16:02:04.964 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2007-03-07 16:02:04.964 Type: SSH_FXP_SETSTAT, Size: 86, Number: 3593
< 2007-03-07 16:02:05.058 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2007-03-07 16:02:05.058 Status/error code: 0
< 2007-03-07 16:02:05.167 Type: SSH_FXP_STATUS, Size: 24, Number: 3593
< 2007-03-07 16:02:05.167 Status/error code: 0
. 2007-03-07 16:02:05.167 File: "manifest_info_ANZ_0162794_ACK.xml"
. 2007-03-07 16:02:05.167 Copying "manifest_info_ANZ_0162794_ACK.xml" to remote directory started.
. 2007-03-07 16:02:05.167 Ascii transfer mode selected.
. 2007-03-07 16:02:05.167 Opening remote file.
> 2007-03-07 16:02:05.167 Type: SSH_FXP_OPEN, Size: 86, Number: 4099
< 2007-03-07 16:02:05.277 Type: SSH_FXP_HANDLE, Size: 13, Number: 4099
> 2007-03-07 16:02:05.277 Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
> 2007-03-07 16:02:05.277 Type: SSH_FXP_SETSTAT, Size: 86, Number: 4361
< 2007-03-07 16:02:05.370 Type: SSH_FXP_STATUS, Size: 24, Number: 4612
< 2007-03-07 16:02:05.370 Status/error code: 0
< 2007-03-07 16:02:05.464 Type: SSH_FXP_STATUS, Size: 24, Number: 4361
< 2007-03-07 16:02:05.464 Status/error code: 0
. 2007-03-07 16:02:05.464 File: "manifest_info_ANZ_0162795_ACK.xml"
. 2007-03-07 16:02:05.464 Copying "manifest_info_ANZ_0162795_ACK.xml" to remote directory started.
. 2007-03-07 16:02:05.464 Ascii transfer mode selected.
. 2007-03-07 16:02:05.464 Opening remote file.
> 2007-03-07 16:02:05.464 Type: SSH_FXP_OPEN, Size: 86, Number: 4867
< 2007-03-07 16:02:05.573 Type: SSH_FXP_HANDLE, Size: 13, Number: 4867
> 2007-03-07 16:02:05.573 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
> 2007-03-07 16:02:05.573 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5129
< 2007-03-07 16:02:05.730 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
< 2007-03-07 16:02:05.730 Status/error code: 0
< 2007-03-07 16:02:05.823 Type: SSH_FXP_STATUS, Size: 24, Number: 5129
< 2007-03-07 16:02:05.823 Status/error code: 0
. 2007-03-07 16:02:05.823 File: "manifest_info_ANZ_0162796_ACK.xml"
. 2007-03-07 16:02:05.823 Copying "manifest_info_ANZ_0162796_ACK.xml" to remote directory started.
. 2007-03-07 16:02:05.823 Ascii transfer mode selected.
. 2007-03-07 16:02:05.823 Opening remote file.
> 2007-03-07 16:02:05.823 Type: SSH_FXP_OPEN, Size: 86, Number: 5635
< 2007-03-07 16:02:05.933 Type: SSH_FXP_HANDLE, Size: 13, Number: 5635
> 2007-03-07 16:02:05.933 Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
> 2007-03-07 16:02:05.933 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5897
< 2007-03-07 16:02:06.027 Type: SSH_FXP_STATUS, Size: 24, Number: 6148
< 2007-03-07 16:02:06.027 Status/error code: 0
< 2007-03-07 16:02:06.136 Type: SSH_FXP_STATUS, Size: 24, Number: 5897
< 2007-03-07 16:02:06.136 Status/error code: 0
. 2007-03-07 16:02:06.136 File: "manifest_info_ANZ_0162797_ACK.xml"
. 2007-03-07 16:02:06.136 Copying "manifest_info_ANZ_0162797_ACK.xml" to remote directory started.
. 2007-03-07 16:02:06.136 Ascii transfer mode selected.
. 2007-03-07 16:02:06.136 Opening remote file.
> 2007-03-07 16:02:06.136 Type: SSH_FXP_OPEN, Size: 86, Number: 6403
< 2007-03-07 16:02:06.230 Type: SSH_FXP_HANDLE, Size: 13, Number: 6403
> 2007-03-07 16:02:06.230 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
> 2007-03-07 16:02:06.230 Type: SSH_FXP_SETSTAT, Size: 86, Number: 6665
< 2007-03-07 16:02:06.370 Type: SSH_FXP_STATUS, Size: 24, Number: 6916
< 2007-03-07 16:02:06.370 Status/error code: 0
< 2007-03-07 16:02:06.464 Type: SSH_FXP_STATUS, Size: 24, Number: 6665
< 2007-03-07 16:02:06.464 Status/error code: 0
. 2007-03-07 16:02:06.464 File: "manifest_info_ANZ_0162798_ACK.xml"
. 2007-03-07 16:02:06.464 Copying "manifest_info_ANZ_0162798_ACK.xml" to remote directory started.
. 2007-03-07 16:02:06.464 Ascii transfer mode selected.
. 2007-03-07 16:02:06.464 Opening remote file.
> 2007-03-07 16:02:06.464 Type: SSH_FXP_OPEN, Size: 86, Number: 7171
< 2007-03-07 16:02:06.558 Type: SSH_FXP_HANDLE, Size: 13, Number: 7171
> 2007-03-07 16:02:06.558 Type: SSH_FXP_CLOSE, Size: 13, Number: 7684
> 2007-03-07 16:02:06.558 Type: SSH_FXP_SETSTAT, Size: 86, Number: 7433
< 2007-03-07 16:02:06.636 Type: SSH_FXP_STATUS, Size: 24, Number: 7684
< 2007-03-07 16:02:06.636 Status/error code: 0
< 2007-03-07 16:02:06.730 Type: SSH_FXP_STATUS, Size: 24, Number: 7433
< 2007-03-07 16:02:06.730 Status/error code: 0
. 2007-03-07 16:02:06.730 File: "manifest_info_ANZ_0162799_ACK.xml"
. 2007-03-07 16:02:06.730 Copying "manifest_info_ANZ_0162799_ACK.xml" to remote directory started.
. 2007-03-07 16:02:06.730 Ascii transfer mode selected.
. 2007-03-07 16:02:06.730 Opening remote file.
> 2007-03-07 16:02:06.730 Type: SSH_FXP_OPEN, Size: 86, Number: 7939
< 2007-03-07 16:02:06.839 Type: SSH_FXP_HANDLE, Size: 13, Number: 7939
> 2007-03-07 16:02:06.839 Type: SSH_FXP_CLOSE, Size: 13, Number: 8452
> 2007-03-07 16:02:06.839 Type: SSH_FXP_SETSTAT, Size: 86, Number: 8201
< 2007-03-07 16:02:06.933 Type: SSH_FXP_STATUS, Size: 24, Number: 8452
< 2007-03-07 16:02:06.933 Status/error code: 0
< 2007-03-07 16:02:07.042 Type: SSH_FXP_STATUS, Size: 24, Number: 8201
< 2007-03-07 16:02:07.042 Status/error code: 0
. 2007-03-07 16:02:07.042 File: "manifest_info_ANZ_0162800_ACK.xml"
. 2007-03-07 16:02:07.042 Copying "manifest_info_ANZ_0162800_ACK.xml" to remote directory started.
. 2007-03-07 16:02:07.042 Ascii transfer mode selected.
. 2007-03-07 16:02:07.042 Opening remote file.
> 2007-03-07 16:02:07.042 Type: SSH_FXP_OPEN, Size: 86, Number: 8707
< 2007-03-07 16:02:07.136 Type: SSH_FXP_HANDLE, Size: 13, Number: 8707
> 2007-03-07 16:02:07.136 Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
> 2007-03-07 16:02:07.136 Type: SSH_FXP_SETSTAT, Size: 86, Number: 8969
< 2007-03-07 16:02:07.230 Type: SSH_FXP_STATUS, Size: 24, Number: 9220
< 2007-03-07 16:02:07.230 Status/error code: 0
< 2007-03-07 16:02:07.323 Type: SSH_FXP_STATUS, Size: 29, Number: 8969
< 2007-03-07 16:02:07.323 Status/error code: 2, Message: 8969, Server: No such file, Language:
* 2007-03-07 16:02:07.339 (ETerminal) No such file or directory.
* 2007-03-07 16:02:07.339 Error code: 2
* 2007-03-07 16:02:07.339 Error message from server: No such file
* 2007-03-07 16:02:07.339 Request code: 9
. 2007-03-07 16:02:07.339 Asking user:
. 2007-03-07 16:02:07.355 Upload of file 'manifest_info_ANZ_0162800_ACK.xml' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("No such file or directory.
. 2007-03-07 16:02:07.355 Error code: 2
. 2007-03-07 16:02:07.355 Error message from server: No such file
. 2007-03-07 16:02:07.355 Request code: 9")
* 2007-03-07 16:02:07.355 (EScpSkipFile) Upload of file 'manifest_info_ANZ_0162800_ACK.xml' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2007-03-07 16:02:07.355 No such file or directory.
* 2007-03-07 16:02:07.355 Error code: 2
* 2007-03-07 16:02:07.355 Error message from server: No such file
* 2007-03-07 16:02:07.355 Request code: 9
. 2007-03-07 16:02:07.355 Closing connection.
. 2007-03-07 16:30:01.292 --------------------------------------------------------------------------
. 2007-03-07 16:30:01.292 WinSCP Version 3.8.2 (Build 330) (OS 5.0.2195 Service Pack 4)
. 2007-03-07 16:30:01.292 Login time: Wednesday, March 07, 2007 4:30:01 PM
. 2007-03-07 16:30:01.292 Session name: USRpg@10.10.10.10
. 2007-03-07 16:30:01.292 Host name: 10.10.10.10 (Port: 22)
. 2007-03-07 16:30:01.292 User name: USRpg (Password: Yes, Key file: No)
. 2007-03-07 16:30:01.292 Transfer Protocol: SFTP (SCP)
. 2007-03-07 16:30:01.292 SSH protocol version: 2; Compression: No
. 2007-03-07 16:30:01.292 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-03-07 16:30:01.292 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-03-07 16:30:01.292 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-03-07 16:30:01.292 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-03-07 16:30:01.292 SFTP Bugs: -,-,-
. 2007-03-07 16:30:01.292 Proxy: none
. 2007-03-07 16:30:01.292 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-03-07 16:30:01.292 Shell: default, EOL: 0
. 2007-03-07 16:30:01.292 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-03-07 16:30:01.292 Cache directory changes: Yes, Permanent: Yes
. 2007-03-07 16:30:01.292 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-03-07 16:30:01.292 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-03-07 16:30:01.292 Looking up host "10.10.10.10"
. 2007-03-07 16:30:01.292 Connecting to 10.10.10.10 port 22
. 2007-03-07 16:30:01.448 Server version: SSH-2.0-OpenSSH_4.3
. 2007-03-07 16:30:01.448 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-03-07 16:30:01.448 Using SSH protocol version 2
. 2007-03-07 16:30:01.542 Doing Diffie-Hellman group exchange
. 2007-03-07 16:30:01.839 Doing Diffie-Hellman key exchange
. 2007-03-07 16:30:02.370 Host key fingerprint is:
. 2007-03-07 16:30:02.370 ssh-rsa 2048 79:25:e4:50:76:62:a8:b9:95:56:7a:51:3a:48:a7:a9
. 2007-03-07 16:30:02.370 Initialised AES-256 client->server encryption
. 2007-03-07 16:30:02.370 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-03-07 16:30:02.370 Initialised AES-256 server->client encryption
. 2007-03-07 16:30:02.370 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-03-07 16:30:02.573 Using username "USRpg".
. 2007-03-07 16:30:02.698 Keyboard-interactive authentication refused
. 2007-03-07 16:30:02.698 Session password prompt (USRpg@10.10.10.10's password: )
. 2007-03-07 16:30:02.698 Using stored password.
! 2007-03-07 16:30:02.698 Authenticating with pre-entered password.
. 2007-03-07 16:30:02.698 Sent password
. 2007-03-07 16:30:02.745 Access granted
. 2007-03-07 16:30:02.823 Opened channel for session
. 2007-03-07 16:30:02.902 Started a shell/command
. 2007-03-07 16:30:02.902 --------------------------------------------------------------------------
. 2007-03-07 16:30:02.902 Using SFTP protocol.
. 2007-03-07 16:30:02.902 Doing startup conversation with host.
> 2007-03-07 16:30:02.902 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2007-03-07 16:30:03.214 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2007-03-07 16:30:03.214 SFTP version 3 negotiated.
. 2007-03-07 16:30:03.214 We believe the server has signed timestamps bug
. 2007-03-07 16:30:03.214 We will use UTF-8 strings for status messages only
. 2007-03-07 16:30:03.214 Limiting packet size to OpenSSH limit of 262148 bytes
. 2007-03-07 16:30:03.214 Getting current directory name.
. 2007-03-07 16:30:03.214 Getting real path for '.'
> 2007-03-07 16:30:03.214 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2007-03-07 16:30:03.308 Type: SSH_FXP_NAME, Size: 43, Number: 16
. 2007-03-07 16:30:03.308 Real path is '/home/USRpg'
. 2007-03-07 16:30:03.308 Startup conversation with host finished.
. 2007-03-07 16:30:03.308 Cached directory change via "PG-Incoming" to "/cygdrive/d/ftp/incoming/pg".
. 2007-03-07 16:30:03.308 Getting current directory name.
. 2007-03-07 16:30:03.308 Copying 22 files/directories to remote directory "/cygdrive/d/ftp/incoming/pg"
. 2007-03-07 16:30:03.308 PrTime: Yes; PrRO: Yes; Rght: rwxrwxrwx; PrR: Yes (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2007-03-07 16:30:03.308 TM: M; ClAr: No; ExclM(No):
. 2007-03-07 16:30:03.308 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-03-07 16:30:03.308 File: "manifest_info_ANZ_0162775_ACK.xml"
. 2007-03-07 16:30:03.308 Copying "manifest_info_ANZ_0162775_ACK.xml" to remote directory started.
. 2007-03-07 16:30:03.323 Ascii transfer mode selected.
. 2007-03-07 16:30:03.323 Opening remote file.
> 2007-03-07 16:30:03.323 Type: SSH_FXP_OPEN, Size: 86, Number: 259
< 2007-03-07 16:30:03.417 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2007-03-07 16:30:03.417 Type: SSH_FXP_CLOSE, Size: 13, Number: 772
> 2007-03-07 16:30:03.417 Type: SSH_FXP_SETSTAT, Size: 86, Number: 521
< 2007-03-07 16:30:03.495 Type: SSH_FXP_STATUS, Size: 24, Number: 772
< 2007-03-07 16:30:03.495 Status/error code: 0
< 2007-03-07 16:30:03.589 Type: SSH_FXP_STATUS, Size: 24, Number: 521
< 2007-03-07 16:30:03.589 Status/error code: 0
. 2007-03-07 16:30:03.589 File: "manifest_info_ANZ_0162790_ACK.xml"
. 2007-03-07 16:30:03.589 Copying "manifest_info_ANZ_0162790_ACK.xml" to remote directory started.
. 2007-03-07 16:30:03.589 Ascii transfer mode selected.
. 2007-03-07 16:30:03.589 Opening remote file.
> 2007-03-07 16:30:03.589 Type: SSH_FXP_OPEN, Size: 86, Number: 1027
< 2007-03-07 16:30:03.698 Type: SSH_FXP_HANDLE, Size: 13, Number: 1027
> 2007-03-07 16:30:03.698 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
> 2007-03-07 16:30:03.698 Type: SSH_FXP_SETSTAT, Size: 86, Number: 1289
< 2007-03-07 16:30:03.792 Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< 2007-03-07 16:30:03.792 Status/error code: 0
< 2007-03-07 16:30:03.902 Type: SSH_FXP_STATUS, Size: 24, Number: 1289
< 2007-03-07 16:30:03.902 Status/error code: 0
. 2007-03-07 16:30:03.902 File: "manifest_info_ANZ_0162791_ACK.xml"
. 2007-03-07 16:30:03.902 Copying "manifest_info_ANZ_0162791_ACK.xml" to remote directory started.
. 2007-03-07 16:30:03.902 Ascii transfer mode selected.
. 2007-03-07 16:30:03.902 Opening remote file.
> 2007-03-07 16:30:03.902 Type: SSH_FXP_OPEN, Size: 86, Number: 1795
< 2007-03-07 16:30:03.995 Type: SSH_FXP_HANDLE, Size: 13, Number: 1795
> 2007-03-07 16:30:03.995 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
> 2007-03-07 16:30:03.995 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2057
< 2007-03-07 16:30:04.089 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
< 2007-03-07 16:30:04.089 Status/error code: 0
< 2007-03-07 16:30:04.198 Type: SSH_FXP_STATUS, Size: 24, Number: 2057
< 2007-03-07 16:30:04.198 Status/error code: 0
. 2007-03-07 16:30:04.198 File: "manifest_info_ANZ_0162792_ACK.xml"
. 2007-03-07 16:30:04.198 Copying "manifest_info_ANZ_0162792_ACK.xml" to remote directory started.
. 2007-03-07 16:30:04.198 Ascii transfer mode selected.
. 2007-03-07 16:30:04.198 Opening remote file.
> 2007-03-07 16:30:04.198 Type: SSH_FXP_OPEN, Size: 86, Number: 2563
< 2007-03-07 16:30:04.308 Type: SSH_FXP_HANDLE, Size: 13, Number: 2563
> 2007-03-07 16:30:04.308 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2007-03-07 16:30:04.308 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2825
< 2007-03-07 16:30:04.402 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
< 2007-03-07 16:30:04.402 Status/error code: 0
< 2007-03-07 16:30:04.511 Type: SSH_FXP_STATUS, Size: 24, Number: 2825
< 2007-03-07 16:30:04.511 Status/error code: 0
. 2007-03-07 16:30:04.511 File: "manifest_info_ANZ_0162793_ACK.xml"
. 2007-03-07 16:30:04.511 Copying "manifest_info_ANZ_0162793_ACK.xml" to remote directory started.
. 2007-03-07 16:30:04.511 Ascii transfer mode selected.
. 2007-03-07 16:30:04.511 Opening remote file.
> 2007-03-07 16:30:04.511 Type: SSH_FXP_OPEN, Size: 86, Number: 3331
< 2007-03-07 16:30:04.620 Type: SSH_FXP_HANDLE, Size: 13, Number: 3331
> 2007-03-07 16:30:04.620 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2007-03-07 16:30:04.620 Type: SSH_FXP_SETSTAT, Size: 86, Number: 3593
< 2007-03-07 16:30:04.714 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2007-03-07 16:30:04.714 Status/error code: 0
< 2007-03-07 16:30:04.823 Type: SSH_FXP_STATUS, Size: 24, Number: 3593
< 2007-03-07 16:30:04.823 Status/error code: 0
. 2007-03-07 16:30:04.823 File: "manifest_info_ANZ_0162794_ACK.xml"
. 2007-03-07 16:30:04.823 Copying "manifest_info_ANZ_0162794_ACK.xml" to remote directory started.
. 2007-03-07 16:30:04.823 Ascii transfer mode selected.
. 2007-03-07 16:30:04.823 Opening remote file.
> 2007-03-07 16:30:04.823 Type: SSH_FXP_OPEN, Size: 86, Number: 4099
< 2007-03-07 16:30:04.933 Type: SSH_FXP_HANDLE, Size: 13, Number: 4099
> 2007-03-07 16:30:04.933 Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
> 2007-03-07 16:30:04.933 Type: SSH_FXP_SETSTAT, Size: 86, Number: 4361
< 2007-03-07 16:30:05.011 Type: SSH_FXP_STATUS, Size: 24, Number: 4612
< 2007-03-07 16:30:05.011 Status/error code: 0
< 2007-03-07 16:30:05.120 Type: SSH_FXP_STATUS, Size: 24, Number: 4361
< 2007-03-07 16:30:05.120 Status/error code: 0
. 2007-03-07 16:30:05.120 File: "manifest_info_ANZ_0162795_ACK.xml"
. 2007-03-07 16:30:05.120 Copying "manifest_info_ANZ_0162795_ACK.xml" to remote directory started.
. 2007-03-07 16:30:05.120 Ascii transfer mode selected.
. 2007-03-07 16:30:05.120 Opening remote file.
> 2007-03-07 16:30:05.120 Type: SSH_FXP_OPEN, Size: 86, Number: 4867
< 2007-03-07 16:30:05.230 Type: SSH_FXP_HANDLE, Size: 13, Number: 4867
> 2007-03-07 16:30:05.230 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
> 2007-03-07 16:30:05.230 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5129
< 2007-03-07 16:30:05.323 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
< 2007-03-07 16:30:05.323 Status/error code: 0
< 2007-03-07 16:30:05.433 Type: SSH_FXP_STATUS, Size: 24, Number: 5129
< 2007-03-07 16:30:05.433 Status/error code: 0
. 2007-03-07 16:30:05.433 File: "manifest_info_ANZ_0162796_ACK.xml"
. 2007-03-07 16:30:05.433 Copying "manifest_info_ANZ_0162796_ACK.xml" to remote directory started.
. 2007-03-07 16:30:05.433 Ascii transfer mode selected.
. 2007-03-07 16:30:05.433 Opening remote file.
> 2007-03-07 16:30:05.433 Type: SSH_FXP_OPEN, Size: 86, Number: 5635
< 2007-03-07 16:30:05.527 Type: SSH_FXP_HANDLE, Size: 13, Number: 5635
> 2007-03-07 16:30:05.527 Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
> 2007-03-07 16:30:05.527 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5897
< 2007-03-07 16:30:05.620 Type: SSH_FXP_STATUS, Size: 24, Number: 6148
< 2007-03-07 16:30:05.620 Status/error code: 0
< 2007-03-07 16:30:05.730 Type: SSH_FXP_STATUS, Size: 24, Number: 5897
< 2007-03-07 16:30:05.730 Status/error code: 0
. 2007-03-07 16:30:05.730 File: "manifest_info_ANZ_0162797_ACK.xml"
. 2007-03-07 16:30:05.730 Copying "manifest_info_ANZ_0162797_ACK.xml" to remote directory started.
. 2007-03-07 16:30:05.730 Ascii transfer mode selected.
. 2007-03-07 16:30:05.730 Opening remote file.
> 2007-03-07 16:30:05.730 Type: SSH_FXP_OPEN, Size: 86, Number: 6403
< 2007-03-07 16:30:05.839 Type: SSH_FXP_HANDLE, Size: 13, Number: 6403
> 2007-03-07 16:30:05.839 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
> 2007-03-07 16:30:05.839 Type: SSH_FXP_SETSTAT, Size: 86, Number: 6665
< 2007-03-07 16:30:05.933 Type: SSH_FXP_STATUS, Size: 24, Number: 6916
< 2007-03-07 16:30:05.933 Status/error code: 0
< 2007-03-07 16:30:06.042 Type: SSH_FXP_STATUS, Size: 24, Number: 6665
< 2007-03-07 16:30:06.042 Status/error code: 0
. 2007-03-07 16:30:06.042 File: "manifest_info_ANZ_0162798_ACK.xml"
. 2007-03-07 16:30:06.042 Copying "manifest_info_ANZ_0162798_ACK.xml" to remote directory started.
. 2007-03-07 16:30:06.042 Ascii transfer mode selected.
. 2007-03-07 16:30:06.042 Opening remote file.
> 2007-03-07 16:30:06.042 Type: SSH_FXP_OPEN, Size: 86, Number: 7171
< 2007-03-07 16:30:06.136 Type: SSH_FXP_HANDLE, Size: 13, Number: 7171
> 2007-03-07 16:30:06.136 Type: SSH_FXP_CLOSE, Size: 13, Number: 7684
> 2007-03-07 16:30:06.136 Type: SSH_FXP_SETSTAT, Size: 86, Number: 7433
< 2007-03-07 16:30:06.245 Type: SSH_FXP_STATUS, Size: 24, Number: 7684
< 2007-03-07 16:30:06.245 Status/error code: 0
< 2007-03-07 16:30:06.355 Type: SSH_FXP_STATUS, Size: 24, Number: 7433
< 2007-03-07 16:30:06.355 Status/error code: 0
. 2007-03-07 16:30:06.355 File: "manifest_info_ANZ_0162799_ACK.xml"
. 2007-03-07 16:30:06.355 Copying "manifest_info_ANZ_0162799_ACK.xml" to remote directory started.
. 2007-03-07 16:30:06.355 Ascii transfer mode selected.
. 2007-03-07 16:30:06.355 Opening remote file.
> 2007-03-07 16:30:06.355 Type: SSH_FXP_OPEN, Size: 86, Number: 7939
< 2007-03-07 16:30:06.448 Type: SSH_FXP_HANDLE, Size: 13, Number: 7939
> 2007-03-07 16:30:06.448 Type: SSH_FXP_CLOSE, Size: 13, Number: 8452
> 2007-03-07 16:30:06.448 Type: SSH_FXP_SETSTAT, Size: 86, Number: 8201
< 2007-03-07 16:30:06.511 Type: SSH_FXP_STATUS, Size: 24, Number: 8452
< 2007-03-07 16:30:06.511 Status/error code: 0
< 2007-03-07 16:30:06.605 Type: SSH_FXP_STATUS, Size: 29, Number: 8201
< 2007-03-07 16:30:06.605 Status/error code: 2, Message: 8201, Server: No such file, Language:
* 2007-03-07 16:30:06.605 (ETerminal) No such file or directory.
* 2007-03-07 16:30:06.605 Error code: 2
* 2007-03-07 16:30:06.605 Error message from server: No such file
* 2007-03-07 16:30:06.605 Request code: 9
. 2007-03-07 16:30:06.605 Asking user:
. 2007-03-07 16:30:06.605 Upload of file 'manifest_info_ANZ_0162799_ACK.xml' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("No such file or directory.
. 2007-03-07 16:30:06.605 Error code: 2
. 2007-03-07 16:30:06.605 Error message from server: No such file
. 2007-03-07 16:30:06.605 Request code: 9")
* 2007-03-07 16:30:06.605 (EScpSkipFile) Upload of file 'manifest_info_ANZ_0162799_ACK.xml' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2007-03-07 16:30:06.605 No such file or directory.
. 2007-03-07 16:30:06.620 Closing connection.
. 2007-03-07 16:30:49.573 --------------------------------------------------------------------------
. 2007-03-07 16:30:49.573 WinSCP Version 3.8.2 (Build 330) (OS 5.0.2195 Service Pack 4)
. 2007-03-07 16:30:49.573 Login time: Wednesday, March 07, 2007 4:30:49 PM
. 2007-03-07 16:30:49.573 Session name: USRpg@10.10.10.10
. 2007-03-07 16:30:49.573 Host name: 10.10.10.10 (Port: 22)
. 2007-03-07 16:30:49.573 User name: USRpg (Password: Yes, Key file: No)
. 2007-03-07 16:30:49.573 Transfer Protocol: SFTP (SCP)
. 2007-03-07 16:30:49.573 SSH protocol version: 2; Compression: No
. 2007-03-07 16:30:49.573 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-03-07 16:30:49.573 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-03-07 16:30:49.573 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-03-07 16:30:49.573 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-03-07 16:30:49.573 SFTP Bugs: -,-,-
. 2007-03-07 16:30:49.573 Proxy: none
. 2007-03-07 16:30:49.573 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-03-07 16:30:49.573 Shell: default, EOL: 0
. 2007-03-07 16:30:49.573 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-03-07 16:30:49.573 Cache directory changes: Yes, Permanent: Yes
. 2007-03-07 16:30:49.573 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-03-07 16:30:49.573 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-03-07 16:30:49.573 Looking up host "10.10.10.10"
. 2007-03-07 16:30:49.573 Connecting to 10.10.10.10 port 22
. 2007-03-07 16:30:49.714 Server version: SSH-2.0-OpenSSH_4.3
. 2007-03-07 16:30:49.714 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-03-07 16:30:49.714 Using SSH protocol version 2
. 2007-03-07 16:30:49.808 Doing Diffie-Hellman group exchange
. 2007-03-07 16:30:50.073 Doing Diffie-Hellman key exchange
. 2007-03-07 16:30:50.527 Host key fingerprint is:
. 2007-03-07 16:30:50.527 ssh-rsa 2048 79:25:e4:50:76:62:a8:b9:95:56:7a:51:3a:48:a7:a9
. 2007-03-07 16:30:50.527 Initialised AES-256 client->server encryption
. 2007-03-07 16:30:50.527 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-03-07 16:30:50.527 Initialised AES-256 server->client encryption
. 2007-03-07 16:30:50.527 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-03-07 16:30:50.808 Using username "USRpg".
. 2007-03-07 16:30:50.917 Keyboard-interactive authentication refused
. 2007-03-07 16:30:50.917 Session password prompt (USRpg@10.10.10.10's password: )
. 2007-03-07 16:30:50.917 Using stored password.
! 2007-03-07 16:30:50.917 Authenticating with pre-entered password.
. 2007-03-07 16:30:50.917 Sent password
. 2007-03-07 16:30:50.980 Access granted
. 2007-03-07 16:30:51.042 Opened channel for session
. 2007-03-07 16:30:51.120 Started a shell/command
. 2007-03-07 16:30:51.120 --------------------------------------------------------------------------
. 2007-03-07 16:30:51.120 Using SFTP protocol.
. 2007-03-07 16:30:51.120 Doing startup conversation with host.
> 2007-03-07 16:30:51.120 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2007-03-07 16:30:51.370 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2007-03-07 16:30:51.370 SFTP version 3 negotiated.
. 2007-03-07 16:30:51.370 We believe the server has signed timestamps bug
. 2007-03-07 16:30:51.370 We will use UTF-8 strings for status messages only
. 2007-03-07 16:30:51.370 Limiting packet size to OpenSSH limit of 262148 bytes
. 2007-03-07 16:30:51.370 Getting current directory name.
. 2007-03-07 16:30:51.370 Getting real path for '.'
> 2007-03-07 16:30:51.370 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2007-03-07 16:30:51.464 Type: SSH_FXP_NAME, Size: 43, Number: 16
. 2007-03-07 16:30:51.464 Real path is '/home/USRpg'
. 2007-03-07 16:30:51.464 Startup conversation with host finished.
. 2007-03-07 16:30:51.464 Cached directory change via "PG-Incoming" to "/cygdrive/d/ftp/incoming/pg".
. 2007-03-07 16:30:51.464 Getting current directory name.
. 2007-03-07 16:30:51.464 Copying 27 files/directories to remote directory "/cygdrive/d/ftp/incoming/pg"
. 2007-03-07 16:30:51.464 PrTime: Yes; PrRO: Yes; Rght: rwxrwxrwx; PrR: Yes (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2007-03-07 16:30:51.464 TM: M; ClAr: No; ExclM(No):
. 2007-03-07 16:30:51.464 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-03-07 16:30:51.464 File: "manifest_info_ANZ_0162775_ACK.xml"
. 2007-03-07 16:30:51.464 Copying "manifest_info_ANZ_0162775_ACK.xml" to remote directory started.
. 2007-03-07 16:30:51.464 Ascii transfer mode selected.
. 2007-03-07 16:30:51.464 Opening remote file.
> 2007-03-07 16:30:51.464 Type: SSH_FXP_OPEN, Size: 86, Number: 259
< 2007-03-07 16:30:51.573 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2007-03-07 16:30:51.573 Type: SSH_FXP_CLOSE, Size: 13, Number: 772
> 2007-03-07 16:30:51.573 Type: SSH_FXP_SETSTAT, Size: 86, Number: 521
< 2007-03-07 16:30:51.667 Type: SSH_FXP_STATUS, Size: 24, Number: 772
< 2007-03-07 16:30:51.667 Status/error code: 0
< 2007-03-07 16:30:51.777 Type: SSH_FXP_STATUS, Size: 24, Number: 521
< 2007-03-07 16:30:51.777 Status/error code: 0
. 2007-03-07 16:30:51.777 File: "manifest_info_ANZ_0162777_ACK.xml"
. 2007-03-07 16:30:51.777 Copying "manifest_info_ANZ_0162777_ACK.xml" to remote directory started.
. 2007-03-07 16:30:51.777 Ascii transfer mode selected.
. 2007-03-07 16:30:51.777 Opening remote file.
> 2007-03-07 16:30:51.777 Type: SSH_FXP_OPEN, Size: 86, Number: 1027
< 2007-03-07 16:30:51.886 Type: SSH_FXP_HANDLE, Size: 13, Number: 1027
> 2007-03-07 16:30:51.886 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
> 2007-03-07 16:30:51.886 Type: SSH_FXP_SETSTAT, Size: 86, Number: 1289
< 2007-03-07 16:30:51.980 Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< 2007-03-07 16:30:51.980 Status/error code: 0
< 2007-03-07 16:30:52.089 Type: SSH_FXP_STATUS, Size: 24, Number: 1289
< 2007-03-07 16:30:52.089 Status/error code: 0
. 2007-03-07 16:30:52.089 File: "manifest_info_ANZ_0162781_ACK.xml"
. 2007-03-07 16:30:52.089 Copying "manifest_info_ANZ_0162781_ACK.xml" to remote directory started.
. 2007-03-07 16:30:52.089 Ascii transfer mode selected.
. 2007-03-07 16:30:52.089 Opening remote file.
> 2007-03-07 16:30:52.089 Type: SSH_FXP_OPEN, Size: 86, Number: 1795
< 2007-03-07 16:30:52.198 Type: SSH_FXP_HANDLE, Size: 13, Number: 1795
> 2007-03-07 16:30:52.198 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
> 2007-03-07 16:30:52.198 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2057
< 2007-03-07 16:30:52.292 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
< 2007-03-07 16:30:52.292 Status/error code: 0
< 2007-03-07 16:30:52.402 Type: SSH_FXP_STATUS, Size: 24, Number: 2057
< 2007-03-07 16:30:52.402 Status/error code: 0
. 2007-03-07 16:30:52.402 File: "manifest_info_ANZ_0162785_ACK.xml"
. 2007-03-07 16:30:52.402 Copying "manifest_info_ANZ_0162785_ACK.xml" to remote directory started.
. 2007-03-07 16:30:52.402 Ascii transfer mode selected.
. 2007-03-07 16:30:52.402 Opening remote file.
> 2007-03-07 16:30:52.402 Type: SSH_FXP_OPEN, Size: 86, Number: 2563
< 2007-03-07 16:30:52.495 Type: SSH_FXP_HANDLE, Size: 13, Number: 2563
> 2007-03-07 16:30:52.495 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2007-03-07 16:30:52.495 Type: SSH_FXP_SETSTAT, Size: 86, Number: 2825
< 2007-03-07 16:30:52.589 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
< 2007-03-07 16:30:52.589 Status/error code: 0
< 2007-03-07 16:30:52.698 Type: SSH_FXP_STATUS, Size: 24, Number: 2825
< 2007-03-07 16:30:52.698 Status/error code: 0
. 2007-03-07 16:30:52.698 File: "manifest_info_ANZ_0162786_ACK.xml"
. 2007-03-07 16:30:52.698 Copying "manifest_info_ANZ_0162786_ACK.xml" to remote directory started.
. 2007-03-07 16:30:52.698 Ascii transfer mode selected.
. 2007-03-07 16:30:52.698 Opening remote file.
> 2007-03-07 16:30:52.698 Type: SSH_FXP_OPEN, Size: 86, Number: 3331
< 2007-03-07 16:30:52.792 Type: SSH_FXP_HANDLE, Size: 13, Number: 3331
> 2007-03-07 16:30:52.792 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2007-03-07 16:30:52.792 Type: SSH_FXP_SETSTAT, Size: 86, Number: 3593
< 2007-03-07 16:30:52.886 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2007-03-07 16:30:52.886 Status/error code: 0
< 2007-03-07 16:30:52.995 Type: SSH_FXP_STATUS, Size: 24, Number: 3593
< 2007-03-07 16:30:52.995 Status/error code: 0
. 2007-03-07 16:30:52.995 File: "manifest_info_ANZ_0162787_ACK.xml"
. 2007-03-07 16:30:52.995 Copying "manifest_info_ANZ_0162787_ACK.xml" to remote directory started.
. 2007-03-07 16:30:52.995 Ascii transfer mode selected.
. 2007-03-07 16:30:52.995 Opening remote file.
> 2007-03-07 16:30:52.995 Type: SSH_FXP_OPEN, Size: 86, Number: 4099
< 2007-03-07 16:30:53.105 Type: SSH_FXP_HANDLE, Size: 13, Number: 4099
> 2007-03-07 16:30:53.105 Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
> 2007-03-07 16:30:53.105 Type: SSH_FXP_SETSTAT, Size: 86, Number: 4361
< 2007-03-07 16:30:53.198 Type: SSH_FXP_STATUS, Size: 24, Number: 4612
< 2007-03-07 16:30:53.198 Status/error code: 0
< 2007-03-07 16:30:53.308 Type: SSH_FXP_STATUS, Size: 24, Number: 4361
< 2007-03-07 16:30:53.308 Status/error code: 0
. 2007-03-07 16:30:53.308 File: "manifest_info_ANZ_0162790_ACK.xml"
. 2007-03-07 16:30:53.308 Copying "manifest_info_ANZ_0162790_ACK.xml" to remote directory started.
. 2007-03-07 16:30:53.308 Ascii transfer mode selected.
. 2007-03-07 16:30:53.308 Opening remote file.
> 2007-03-07 16:30:53.308 Type: SSH_FXP_OPEN, Size: 86, Number: 4867
< 2007-03-07 16:30:53.417 Type: SSH_FXP_HANDLE, Size: 13, Number: 4867
> 2007-03-07 16:30:53.417 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
> 2007-03-07 16:30:53.417 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5129
< 2007-03-07 16:30:53.511 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
< 2007-03-07 16:30:53.511 Status/error code: 0
< 2007-03-07 16:30:53.620 Type: SSH_FXP_STATUS, Size: 24, Number: 5129
< 2007-03-07 16:30:53.620 Status/error code: 0
. 2007-03-07 16:30:53.620 File: "manifest_info_ANZ_0162791_ACK.xml"
. 2007-03-07 16:30:53.620 Copying "manifest_info_ANZ_0162791_ACK.xml" to remote directory started.
. 2007-03-07 16:30:53.620 Ascii transfer mode selected.
. 2007-03-07 16:30:53.620 Opening remote file.
> 2007-03-07 16:30:53.620 Type: SSH_FXP_OPEN, Size: 86, Number: 5635
< 2007-03-07 16:30:53.730 Type: SSH_FXP_HANDLE, Size: 13, Number: 5635
> 2007-03-07 16:30:53.730 Type: SSH_FXP_CLOSE, Size: 13, Number: 6148
> 2007-03-07 16:30:53.730 Type: SSH_FXP_SETSTAT, Size: 86, Number: 5897
< 2007-03-07 16:30:53.823 Type: SSH_FXP_STATUS, Size: 24, Number: 6148
< 2007-03-07 16:30:53.823 Status/error code: 0
< 2007-03-07 16:30:53.933 Type: SSH_FXP_STATUS, Size: 24, Number: 5897
< 2007-03-07 16:30:53.933 Status/error code: 0
. 2007-03-07 16:30:53.933 File: "manifest_info_ANZ_0162792_ACK.xml"
. 2007-03-07 16:30:53.933 Copying "manifest_info_ANZ_0162792_ACK.xml" to remote directory started.
. 2007-03-07 16:30:53.933 Ascii transfer mode selected.
. 2007-03-07 16:30:53.933 Opening remote file.
> 2007-03-07 16:30:53.933 Type: SSH_FXP_OPEN, Size: 86, Number: 6403
< 2007-03-07 16:30:54.042 Type: SSH_FXP_HANDLE, Size: 13, Number: 6403
> 2007-03-07 16:30:54.042 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
> 2007-03-07 16:30:54.042 Type: SSH_FXP_SETSTAT, Size: 86, Number: 6665
< 2007-03-07 16:30:54.136 Type: SSH_FXP_STATUS, Size: 24, Number: 6916
< 2007-03-07 16:30:54.136 Status/error code: 0
< 2007-03-07 16:30:54.245 Type: SSH_FXP_STATUS, Size: 24, Number: 6665
< 2007-03-07 16:30:54.245 Status/error code: 0
. 2007-03-07 16:30:54.245 File: "manifest_info_ANZ_0162793_ACK.xml"
. 2007-03-07 16:30:54.245 Copying "manifest_info_ANZ_0162793_ACK.xml" to remote directory started.
. 2007-03-07 16:30:54.245 Ascii transfer mode selected.
. 2007-03-07 16:30:54.245 Opening remote file.
> 2007-03-07 16:30:54.245 Type: SSH_FXP_OPEN, Size: 86, Number: 7171
< 2007-03-07 16:30:54.355 Type: SSH_FXP_HANDLE, Size: 13, Number: 7171
> 2007-03-07 16:30:54.355 Type: SSH_FXP_CLOSE, Size: 13, Number: 7684
> 2007-03-07 16:30:54.355 Type: SSH_FXP_SETSTAT, Size: 86, Number: 7433
< 2007-03-07 16:30:54.448 Type: SSH_FXP_STATUS, Size: 24, Number: 7684
< 2007-03-07 16:30:54.448 Status/error code: 0
< 2007-03-07 16:30:54.542 Type: SSH_FXP_STATUS, Size: 24, Number: 7433
< 2007-03-07 16:30:54.542 Status/error code: 0
. 2007-03-07 16:30:54.542 File: "manifest_info_ANZ_0162794_ACK.xml"
. 2007-03-07 16:30:54.542 Copying "manifest_info_ANZ_0162794_ACK.xml" to remote directory started.
. 2007-03-07 16:30:54.542 Ascii transfer mode selected.
. 2007-03-07 16:30:54.542 Opening remote file.
> 2007-03-07 16:30:54.542 Type: SSH_FXP_OPEN, Size: 86, Number: 7939
< 2007-03-07 16:30:54.652 Type: SSH_FXP_HANDLE, Size: 13, Number: 7939
> 2007-03-07 16:30:54.652 Type: SSH_FXP_CLOSE, Size: 13, Number: 8452
> 2007-03-07 16:30:54.652 Type: SSH_FXP_SETSTAT, Size: 86, Number: 8201
< 2007-03-07 16:30:54.745 Type: SSH_FXP_STATUS, Size: 24, Number: 8452
< 2007-03-07 16:30:54.745 Status/error code: 0
< 2007-03-07 16:30:54.855 Type: SSH_FXP_STATUS, Size: 24, Number: 8201
< 2007-03-07 16:30:54.855 Status/error code: 0
. 2007-03-07 16:30:54.855 File: "manifest_info_ANZ_0162795_ACK.xml"
. 2007-03-07 16:30:54.855 Copying "manifest_info_ANZ_0162795_ACK.xml" to remote directory started.
. 2007-03-07 16:30:54.855 Ascii transfer mode selected.
. 2007-03-07 16:30:54.855 Opening remote file.
> 2007-03-07 16:30:54.855 Type: SSH_FXP_OPEN, Size: 86, Number: 8707
< 2007-03-07 16:30:54.964 Type: SSH_FXP_HANDLE, Size: 13, Number: 8707
> 2007-03-07 16:30:54.964 Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
> 2007-03-07 16:30:54.964 Type: SSH_FXP_SETSTAT, Size: 86, Number: 8969
< 2007-03-07 16:30:55.042 Type: SSH_FXP_STATUS, Size: 24, Number: 9220
< 2007-03-07 16:30:55.042 Status/error code: 0
< 2007-03-07 16:30:55.152 Type: SSH_FXP_STATUS, Size: 24, Number: 8969
< 2007-03-07 16:30:55.152 Status/error code: 0
. 2007-03-07 16:30:55.152 File: "manifest_info_ANZ_0162796_ACK.xml"
. 2007-03-07 16:30:55.152 Copying "manifest_info_ANZ_0162796_ACK.xml" to remote directory started.
. 2007-03-07 16:30:55.152 Ascii transfer mode selected.
. 2007-03-07 16:30:55.152 Opening remote file.
> 2007-03-07 16:30:55.152 Type: SSH_FXP_OPEN, Size: 86, Number: 9475
< 2007-03-07 16:30:55.261 Type: SSH_FXP_HANDLE, Size: 13, Number: 9475
> 2007-03-07 16:30:55.261 Type: SSH_FXP_CLOSE, Size: 13, Number: 9988
> 2007-03-07 16:30:55.261 Type: SSH_FXP_SETSTAT, Size: 86, Number: 9737
< 2007-03-07 16:30:55.355 Type: SSH_FXP_STATUS, Size: 24, Number: 9988
< 2007-03-07 16:30:55.355 Status/error code: 0
< 2007-03-07 16:30:55.448 Type: SSH_FXP_STATUS, Size: 24, Number: 9737
< 2007-03-07 16:30:55.448 Status/error code: 0
. 2007-03-07 16:30:55.448 File: "manifest_info_ANZ_0162797_ACK.xml"
. 2007-03-07 16:30:55.448 Copying "manifest_info_ANZ_0162797_ACK.xml" to remote directory started.
. 2007-03-07 16:30:55.448 Ascii transfer mode selected.
. 2007-03-07 16:30:55.448 Opening remote file.
> 2007-03-07 16:30:55.448 Type: SSH_FXP_OPEN, Size: 86, Number: 10243
< 2007-03-07 16:30:55.558 Type: SSH_FXP_HANDLE, Size: 13, Number: 10243
> 2007-03-07 16:30:55.558 Type: SSH_FXP_CLOSE, Size: 13, Number: 10756
> 2007-03-07 16:30:55.558 Type: SSH_FXP_SETSTAT, Size: 86, Number: 10505
< 2007-03-07 16:30:55.652 Type: SSH_FXP_STATUS, Size: 24, Number: 10756
< 2007-03-07 16:30:55.652 Status/error code: 0
< 2007-03-07 16:30:55.745 Type: SSH_FXP_STATUS, Size: 24, Number: 10505
< 2007-03-07 16:30:55.745 Status/error code: 0
. 2007-03-07 16:30:55.745 File: "manifest_info_ANZ_0162798_ACK.xml"
. 2007-03-07 16:30:55.745 Copying "manifest_info_ANZ_0162798_ACK.xml" to remote directory started.
. 2007-03-07 16:30:55.745 Ascii transfer mode selected.
. 2007-03-07 16:30:55.745 Opening remote file.
> 2007-03-07 16:30:55.745 Type: SSH_FXP_OPEN, Size: 86, Number: 11011
< 2007-03-07 16:30:55.855 Type: SSH_FXP_HANDLE, Size: 13, Number: 11011
> 2007-03-07 16:30:55.855 Type: SSH_FXP_CLOSE, Size: 13, Number: 11524
> 2007-03-07 16:30:55.855 Type: SSH_FXP_SETSTAT, Size: 86, Number: 11273
< 2007-03-07 16:30:55.933 Type: SSH_FXP_STATUS, Size: 24, Number: 11524
< 2007-03-07 16:30:55.933 Status/error code: 0
< 2007-03-07 16:30:56.042 Type: SSH_FXP_STATUS, Size: 24, Number: 11273
< 2007-03-07 16:30:56.042 Status/error code: 0
. 2007-03-07 16:30:56.042 File: "manifest_info_ANZ_0162799_ACK.xml"
. 2007-03-07 16:30:56.042 Copying "manifest_info_ANZ_0162799_ACK.xml" to remote directory started.
. 2007-03-07 16:30:56.042 Ascii transfer mode selected.
. 2007-03-07 16:30:56.042 Opening remote file.
> 2007-03-07 16:30:56.042 Type: SSH_FXP_OPEN, Size: 86, Number: 11779
< 2007-03-07 16:30:56.152 Type: SSH_FXP_HANDLE, Size: 13, Number: 11779
> 2007-03-07 16:30:56.152 Type: SSH_FXP_CLOSE, Size: 13, Number: 12292
> 2007-03-07 16:30:56.152 Type: SSH_FXP_SETSTAT, Size: 86, Number: 12041
< 2007-03-07 16:30:56.245 Type: SSH_FXP_STATUS, Size: 24, Number: 12292
< 2007-03-07 16:30:56.245 Status/error code: 0
< 2007-03-07 16:30:56.355 Type: SSH_FXP_STATUS, Size: 24, Number: 12041
< 2007-03-07 16:30:56.355 Status/error code: 0
. 2007-03-07 16:30:56.355 File: "manifest_info_ANZ_0162800_ACK.xml"
. 2007-03-07 16:30:56.355 Copying "manifest_info_ANZ_0162800_ACK.xml" to remote directory started.
. 2007-03-07 16:30:56.355 Ascii transfer mode selected.
. 2007-03-07 16:30:56.355 Opening remote file.
> 2007-03-07 16:30:56.355 Type: SSH_FXP_OPEN, Size: 86, Number: 12547
< 2007-03-07 16:30:56.448 Type: SSH_FXP_HANDLE, Size: 13, Number: 12547
> 2007-03-07 16:30:56.448 Type: SSH_FXP_CLOSE, Size: 13, Number: 13060
> 2007-03-07 16:30:56.448 Type: SSH_FXP_SETSTAT, Size: 86, Number: 12809
< 2007-03-07 16:30:56.542 Type: SSH_FXP_STATUS, Size: 24, Number: 13060
< 2007-03-07 16:30:56.542 Status/error code: 0
< 2007-03-07 16:30:56.652 Type: SSH_FXP_STATUS, Size: 24, Number: 12809
< 2007-03-07 16:30:56.652 Status/error code: 0
. 2007-03-07 16:30:56.652 File: "manifest_info_ANZ_0162801_ACK.xml"
. 2007-03-07 16:30:56.652 Copying "manifest_info_ANZ_0162801_ACK.xml" to remote directory started.
. 2007-03-07 16:30:56.652 Ascii transfer mode selected.
. 2007-03-07 16:30:56.652 Opening remote file.
> 2007-03-07 16:30:56.652 Type: SSH_FXP_OPEN, Size: 86, Number: 13315
< 2007-03-07 16:30:56.761 Type: SSH_FXP_HANDLE, Size: 13, Number: 13315
> 2007-03-07 16:30:56.761 Type: SSH_FXP_CLOSE, Size: 13, Number: 13828
> 2007-03-07 16:30:56.761 Type: SSH_FXP_SETSTAT, Size: 86, Number: 13577
< 2007-03-07 16:30:56.855 Type: SSH_FXP_STATUS, Size: 24, Number: 13828
< 2007-03-07 16:30:56.855 Status/error code: 0
< 2007-03-07 16:30:56.948 Type: SSH_FXP_STATUS, Size: 24, Number: 13577
< 2007-03-07 16:30:56.948 Status/error code: 0
. 2007-03-07 16:30:56.948 File: "manifest_info_ANZ_0162802_ACK.xml"
. 2007-03-07 16:30:56.948 Copying "manifest_info_ANZ_0162802_ACK.xml" to remote directory started.
. 2007-03-07 16:30:56.948 Ascii transfer mode selected.
. 2007-03-07 16:30:56.948 Opening remote file.
> 2007-03-07 16:30:56.948 Type: SSH_FXP_OPEN, Size: 86, Number: 14083
< 2007-03-07 16:30:57.058 Type: SSH_FXP_HANDLE, Size: 13, Number: 14083
> 2007-03-07 16:30:57.058 Type: SSH_FXP_CLOSE, Size: 13, Number: 14596
> 2007-03-07 16:30:57.058 Type: SSH_FXP_SETSTAT, Size: 86, Number: 14345
< 2007-03-07 16:30:57.136 Type: SSH_FXP_STATUS, Size: 24, Number: 14596
< 2007-03-07 16:30:57.136 Status/error code: 0
< 2007-03-07 16:30:57.245 Type: SSH_FXP_STATUS, Size: 24, Number: 14345
< 2007-03-07 16:30:57.245 Status/error code: 0
. 2007-03-07 16:30:57.245 File: "manifest_info_ANZ_0162803_ACK.xml"
. 2007-03-07 16:30:57.245 Copying "manifest_info_ANZ_0162803_ACK.xml" to remote directory started.
. 2007-03-07 16:30:57.245 Ascii transfer mode selected.
. 2007-03-07 16:30:57.245 Opening remote file.
> 2007-03-07 16:30:57.245 Type: SSH_FXP_OPEN, Size: 86, Number: 14851
< 2007-03-07 16:30:57.355 Type: SSH_FXP_HANDLE, Size: 13, Number: 14851
> 2007-03-07 16:30:57.355 Type: SSH_FXP_CLOSE, Size: 13, Number: 15364
> 2007-03-07 16:30:57.355 Type: SSH_FXP_SETSTAT, Size: 86, Number: 15113
< 2007-03-07 16:30:57.448 Type: SSH_FXP_STATUS, Size: 24, Number: 15364
< 2007-03-07 16:30:57.448 Status/error code: 0
< 2007-03-07 16:30:57.558 Type: SSH_FXP_STATUS, Size: 24, Number: 15113
< 2007-03-07 16:30:57.558 Status/error code: 0
. 2007-03-07 16:30:57.558 File: "manifest_info_ANZ_0162804_ACK.xml"
. 2007-03-07 16:30:57.558 Copying "manifest_info_ANZ_0162804_ACK.xml" to remote directory started.
. 2007-03-07 16:30:57.558 Ascii transfer mode selected.
. 2007-03-07 16:30:57.558 Opening remote file.
> 2007-03-07 16:30:57.558 Type: SSH_FXP_OPEN, Size: 86, Number: 15619
< 2007-03-07 16:30:57.667 Type: SSH_FXP_HANDLE, Size: 13, Number: 15619
> 2007-03-07 16:30:57.667 Type: SSH_FXP_CLOSE, Size: 13, Number: 16132
> 2007-03-07 16:30:57.667 Type: SSH_FXP_SETSTAT, Size: 86, Number: 15881
< 2007-03-07 16:30:57.761 Type: SSH_FXP_STATUS, Size: 24, Number: 16132
< 2007-03-07 16:30:57.761 Status/error code: 0
< 2007-03-07 16:30:57.870 Type: SSH_FXP_STATUS, Size: 24, Number: 15881
< 2007-03-07 16:30:57.870 Status/error code: 0
. 2007-03-07 16:30:57.870 File: "manifest_info_ANZ_0162805_ACK.xml"
. 2007-03-07 16:30:57.870 Copying "manifest_info_ANZ_0162805_ACK.xml" to remote directory started.
. 2007-03-07 16:30:57.870 Ascii transfer mode selected.
. 2007-03-07 16:30:57.870 Opening remote file.
> 2007-03-07 16:30:57.870 Type: SSH_FXP_OPEN, Size: 86, Number: 16387
< 2007-03-07 16:30:57.980 Type: SSH_FXP_HANDLE, Size: 13, Number: 16387
> 2007-03-07 16:30:57.980 Type: SSH_FXP_CLOSE, Size: 13, Number: 16900
> 2007-03-07 16:30:57.980 Type: SSH_FXP_SETSTAT, Size: 86, Number: 16649
< 2007-03-07 16:30:58.073 Type: SSH_FXP_STATUS, Size: 24, Number: 16900
< 2007-03-07 16:30:58.073 Status/error code: 0
< 2007-03-07 16:30:58.167 Type: SSH_FXP_STATUS, Size: 24, Number: 16649
< 2007-03-07 16:30:58.167 Status/error code: 0
. 2007-03-07 16:30:58.167 File: "manifest_info_ANZ_0162806_ACK.xml"
. 2007-03-07 16:30:58.167 Copying "manifest_info_ANZ_0162806_ACK.xml" to remote directory started.
. 2007-03-07 16:30:58.167 Ascii transfer mode selected.
. 2007-03-07 16:30:58.167 Opening remote file.
> 2007-03-07 16:30:58.167 Type: SSH_FXP_OPEN, Size: 86, Number: 17155
< 2007-03-07 16:30:58.277 Type: SSH_FXP_HANDLE, Size: 13, Number: 17155
> 2007-03-07 16:30:58.277 Type: SSH_FXP_CLOSE, Size: 13, Number: 17668
> 2007-03-07 16:30:58.277 Type: SSH_FXP_SETSTAT, Size: 86, Number: 17417
< 2007-03-07 16:30:58.370 Type: SSH_FXP_STATUS, Size: 24, Number: 17668
< 2007-03-07 16:30:58.370 Status/error code: 0
< 2007-03-07 16:30:58.480 Type: SSH_FXP_STATUS, Size: 24, Number: 17417
< 2007-03-07 16:30:58.480 Status/error code: 0
. 2007-03-07 16:30:58.480 File: "manifest_info_ANZ_0162807_ACK.xml"
. 2007-03-07 16:30:58.480 Copying "manifest_info_ANZ_0162807_ACK.xml" to remote directory started.
. 2007-03-07 16:30:58.480 Ascii transfer mode selected.
. 2007-03-07 16:30:58.480 Opening remote file.
> 2007-03-07 16:30:58.480 Type: SSH_FXP_OPEN, Size: 86, Number: 17923
< 2007-03-07 16:30:58.589 Type: SSH_FXP_HANDLE, Size: 13, Number: 17923
> 2007-03-07 16:30:58.589 Type: SSH_FXP_CLOSE, Size: 13, Number: 18436
> 2007-03-07 16:30:58.589 Type: SSH_FXP_SETSTAT, Size: 86, Number: 18185
< 2007-03-07 16:30:58.683 Type: SSH_FXP_STATUS, Size: 24, Number: 18436
< 2007-03-07 16:30:58.683 Status/error code: 0
< 2007-03-07 16:30:58.792 Type: SSH_FXP_STATUS, Size: 24, Number: 18185
< 2007-03-07 16:30:58.792 Status/error code: 0
. 2007-03-07 16:30:58.792 File: "manifest_info_ANZ_0162808_ACK.xml"
. 2007-03-07 16:30:58.792 Copying "manifest_info_ANZ_0162808_ACK.xml" to remote directory started.
. 2007-03-07 16:30:58.792 Ascii transfer mode selected.
. 2007-03-07 16:30:58.792 Opening remote file.
> 2007-03-07 16:30:58.792 Type: SSH_FXP_OPEN, Size: 86, Number: 18691
< 2007-03-07 16:30:58.902 Type: SSH_FXP_HANDLE, Size: 13, Number: 18691
> 2007-03-07 16:30:58.902 Type: SSH_FXP_CLOSE, Size: 13, Number: 19204
> 2007-03-07 16:30:58.902 Type: SSH_FXP_SETSTAT, Size: 86, Number: 18953
< 2007-03-07 16:30:58.980 Type: SSH_FXP_STATUS, Size: 24, Number: 19204
< 2007-03-07 16:30:58.980 Status/error code: 0
< 2007-03-07 16:30:59.073 Type: SSH_FXP_STATUS, Size: 24, Number: 18953
< 2007-03-07 16:30:59.073 Status/error code: 0
. 2007-03-07 16:30:59.073 File: "manifest_info_ANZ_0162809_ACK.xml"
. 2007-03-07 16:30:59.073 Copying "manifest_info_ANZ_0162809_ACK.xml" to remote directory started.
. 2007-03-07 16:30:59.073 Ascii transfer mode selected.
. 2007-03-07 16:30:59.073 Opening remote file.
> 2007-03-07 16:30:59.073 Type: SSH_FXP_OPEN, Size: 86, Number: 19459
< 2007-03-07 16:30:59.183 Type: SSH_FXP_HANDLE, Size: 13, Number: 19459
> 2007-03-07 16:30:59.183 Type: SSH_FXP_CLOSE, Size: 13, Number: 19972
> 2007-03-07 16:30:59.183 Type: SSH_FXP_SETSTAT, Size: 86, Number: 19721
< 2007-03-07 16:30:59.277 Type: SSH_FXP_STATUS, Size: 24, Number: 19972
< 2007-03-07 16:30:59.277 Status/error code: 0
< 2007-03-07 16:30:59.386 Type: SSH_FXP_STATUS, Size: 24, Number: 19721
< 2007-03-07 16:30:59.386 Status/error code: 0
. 2007-03-07 16:30:59.386 File: "manifest_info_ANZ_0162810_ACK.xml"
. 2007-03-07 16:30:59.386 Copying "manifest_info_ANZ_0162810_ACK.xml" to remote directory started.
. 2007-03-07 16:30:59.386 Ascii transfer mode selected.
. 2007-03-07 16:30:59.386 Opening remote file.
> 2007-03-07 16:30:59.386 Type: SSH_FXP_OPEN, Size: 86, Number: 20227
< 2007-03-07 16:30:59.495 Type: SSH_FXP_HANDLE, Size: 13, Number: 20227
> 2007-03-07 16:30:59.495 Type: SSH_FXP_CLOSE, Size: 13, Number: 20740
> 2007-03-07 16:30:59.495 Type: SSH_FXP_SETSTAT, Size: 86, Number: 20489
< 2007-03-07 16:30:59.589 Type: SSH_FXP_STATUS, Size: 24, Number: 20740
< 2007-03-07 16:30:59.589 Status/error code: 0
< 2007-03-07 16:30:59.698 Type: SSH_FXP_STATUS, Size: 24, Number: 20489
< 2007-03-07 16:30:59.698 Status/error code: 0
. 2007-03-07 16:30:59.698 Closing connection.
Thanks.
kls9036
same "error occurred while setting the permissions" problem
Is there any further information on this? The last I see is a log file was posted a couple of weeks ago. We are having the same problem here. WinSCP 3.8.2 (Build 330). Using Windows XP to upload to a Novell server. I don't think it is an actual permissions problem because the directory I am trying to upload to is my personal home directory on the Novell server.
Site Admin -
Re: same "error occurred while setting the permissions" problem
Not yet. I wan't able to find out whether this is client-side or server-side problem.Is there any further information on this?
- boxing_surfer
- 6
- LONDON
error occured while setting the permissions and/or timestamp
I'm getting this problem too.
Client:
WinSCP 4.0.2 (build 344) on WinXP SP2
Server:
VanDyke VShell 2.6.4 (build 448) on Windows Server 2003 SP2
Using SFTP-4 Protocol
Session protocol = SSH-2
SSH implementation = VShell_2_6_4_448 VShell
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-4
Can change permissions = No
Can change owner/group = Yes
Can execute arbitrary command = No
Can create symlink/hardlink = Yes/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = Yes
Can calculate file checksum = No
Native text (ASCII) mode transfers = Yes
My WinSCP copy options are set up as follows:
set permissions = no
preserve timestamps = no
ignore permissions errors = yes
but when i try to upload, overwriting existing files i get this:
* 2007-06-15 15:26:08.017 Error code: 8
* 2007-06-15 15:26:08.017 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:08.017 Request code: 9
. 2007-06-15 15:26:08.017 Asking user:
. 2007-06-15 15:26:08.017 Upload of file 'AGI374.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("The server does not support the operation.
. 2007-06-15 15:26:08.017 Error code: 8
. 2007-06-15 15:26:08.017 Error message from server (en): The request is not supported.
. 2007-06-15 15:26:08.017 Request code: 9")
* 2007-06-15 15:26:09.908 (EScpSkipFile) Upload of file 'AGI374.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2007-06-15 15:26:09.908 The server does not support the operation.
* 2007-06-15 15:26:09.908 Error code: 8
* 2007-06-15 15:26:09.908 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:09.908 Request code: 9
Definitely not a permissions problem on the destination file, as I am the owner and have full control. I've double checked this.
I can understand the part where it says "the server does not support the operation", but I'm confused about why the client is asking the server to do anything with timestamp or permission when both options are explicitly disabled.
Also, shouldn't the option to 'ignore permissions errors' cause such a condition to be handled gracefully??
FULL LOG
. 2007-06-15 15:26:02.189 Copying 7 files/directories to remote directory "/XYZ_Upload/testing/"
. 2007-06-15 15:26:02.189 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2007-06-15 15:26:02.189 TM: M; ClAr: No; ExclM(No):
. 2007-06-15 15:26:02.189 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-06-15 15:26:02.189 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\AGI374.xls"
. 2007-06-15 15:26:02.221 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\AGI374.xls" to remote directory started.
. 2007-06-15 15:26:02.221 Binary transfer mode selected.
. 2007-06-15 15:26:02.221 Checking existence of file.
> 2007-06-15 15:26:02.221 Type: SSH_FXP_LSTAT, Size: 45, Number: 815623
< 2007-06-15 15:26:02.221 Type: SSH_FXP_STATUS, Size: 34, Number: 815364
. 2007-06-15 15:26:02.221 Discarding reserved response
< 2007-06-15 15:26:02.236 Type: SSH_FXP_ATTRS, Size: 112, Number: 815623
. 2007-06-15 15:26:02.236 Checking existence of partially transfered file.
> 2007-06-15 15:26:02.236 Type: SSH_FXP_LSTAT, Size: 54, Number: 815879
< 2007-06-15 15:26:02.252 Type: SSH_FXP_STATUS, Size: 62, Number: 815879
< 2007-06-15 15:26:02.252 Status/error code: 2
. 2007-06-15 15:26:02.252 Asking user:
. 2007-06-15 15:26:02.252 Remote file 'AGI374.xls' already exists. Overwrite?
. 2007-06-15 15:26:02.252 New: 2860544 bytes, 13/06/2007 14:47:58
. 2007-06-15 15:26:02.252 Existing: 2860544 bytes, 15/06/2007 16:19:28 ()
> 2007-06-15 15:26:04.330 Type: SSH_FXP_REMOVE, Size: 41, Number: 816141
< 2007-06-15 15:26:04.346 Type: SSH_FXP_STATUS, Size: 34, Number: 816141
< 2007-06-15 15:26:04.346 Status/error code: 0
. 2007-06-15 15:26:04.346 Opening remote file.
> 2007-06-15 15:26:04.346 Type: SSH_FXP_OPEN, Size: 67, Number: 816387
< 2007-06-15 15:26:04.346 Type: SSH_FXP_HANDLE, Size: 13, Number: 816387
> 2007-06-15 15:26:04.361 Type: SSH_FXP_WRITE, Size: 4121, Number: 816902
. 2007-06-15 15:26:07.955 347 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:26:07.955 Type: SSH_FXP_CLOSE, Size: 13, Number: 861956
< 2007-06-15 15:26:07.970 Type: SSH_FXP_STATUS, Size: 34, Number: 860934
< 2007-06-15 15:26:07.986 Type: SSH_FXP_STATUS, Size: 34, Number: 861190
< 2007-06-15 15:26:08.002 Type: SSH_FXP_STATUS, Size: 34, Number: 861446
< 2007-06-15 15:26:08.017 Type: SSH_FXP_STATUS, Size: 34, Number: 861702
< 2007-06-15 15:26:08.017 Type: SSH_FXP_STATUS, Size: 34, Number: 861956
< 2007-06-15 15:26:08.017 Status/error code: 0
> 2007-06-15 15:26:08.017 Type: SSH_FXP_RENAME, Size: 86, Number: 862226
< 2007-06-15 15:26:08.017 Type: SSH_FXP_STATUS, Size: 34, Number: 862226
> 2007-06-15 15:26:08.017 Type: SSH_FXP_SETSTAT, Size: 66, Number: 816649
< 2007-06-15 15:26:08.017 Type: SSH_FXP_STATUS, Size: 49, Number: 816649
< 2007-06-15 15:26:08.017 Status/error code: 8, Message: 816649, Server: The request is not supported. , Language: en
* 2007-06-15 15:26:08.017 (ETerminal) The server does not support the operation.
. 2007-06-15 15:26:09.924 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Alt120.xls"
. 2007-06-15 15:26:09.924 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Alt120.xls" to remote directory started.
. 2007-06-15 15:26:10.064 Binary transfer mode selected.
. 2007-06-15 15:26:10.064 Checking existence of file.
> 2007-06-15 15:26:10.064 Type: SSH_FXP_LSTAT, Size: 45, Number: 862471
< 2007-06-15 15:26:10.080 Type: SSH_FXP_ATTRS, Size: 112, Number: 862471
. 2007-06-15 15:26:10.080 Checking existence of partially transfered file.
> 2007-06-15 15:26:10.080 Type: SSH_FXP_LSTAT, Size: 54, Number: 862727
< 2007-06-15 15:26:10.080 Type: SSH_FXP_STATUS, Size: 62, Number: 862727
< 2007-06-15 15:26:10.080 Status/error code: 2
> 2007-06-15 15:26:10.080 Type: SSH_FXP_REMOVE, Size: 41, Number: 862989
< 2007-06-15 15:26:10.095 Type: SSH_FXP_STATUS, Size: 34, Number: 862989
< 2007-06-15 15:26:10.095 Status/error code: 0
. 2007-06-15 15:26:10.095 Opening remote file.
> 2007-06-15 15:26:10.095 Type: SSH_FXP_OPEN, Size: 67, Number: 863235
< 2007-06-15 15:26:10.095 Type: SSH_FXP_HANDLE, Size: 13, Number: 863235
> 2007-06-15 15:26:10.111 Type: SSH_FXP_WRITE, Size: 16380, Number: 863750
. 2007-06-15 15:26:23.751 1292 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:26:23.751 Type: SSH_FXP_CLOSE, Size: 13, Number: 1029892
< 2007-06-15 15:26:23.751 Type: SSH_FXP_STATUS, Size: 34, Number: 1028614
< 2007-06-15 15:26:23.767 Type: SSH_FXP_STATUS, Size: 34, Number: 1028870
< 2007-06-15 15:26:23.783 Type: SSH_FXP_STATUS, Size: 34, Number: 1029126
< 2007-06-15 15:26:23.798 Type: SSH_FXP_STATUS, Size: 34, Number: 1029382
< 2007-06-15 15:26:23.814 Type: SSH_FXP_STATUS, Size: 34, Number: 1029638
< 2007-06-15 15:26:23.814 Type: SSH_FXP_STATUS, Size: 34, Number: 1029892
< 2007-06-15 15:26:23.814 Status/error code: 0
> 2007-06-15 15:26:23.814 Type: SSH_FXP_RENAME, Size: 86, Number: 1030162
< 2007-06-15 15:26:23.829 Type: SSH_FXP_STATUS, Size: 34, Number: 1030162
< 2007-06-15 15:26:23.829 Status/error code: 0
> 2007-06-15 15:26:23.829 Type: SSH_FXP_SETSTAT, Size: 66, Number: 863497
< 2007-06-15 15:26:23.829 Type: SSH_FXP_STATUS, Size: 49, Number: 863497
< 2007-06-15 15:26:23.829 Status/error code: 8, Message: 863497, Server: The request is not supported. , Language: en
* 2007-06-15 15:26:23.829 (ETerminal) The server does not support the operation.
* 2007-06-15 15:26:23.829 Error code: 8
* 2007-06-15 15:26:23.829 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:23.829 Request code: 9
. 2007-06-15 15:26:23.829 Asking user:
. 2007-06-15 15:26:23.829 Upload of file 'Alt120.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore
. 2007-06-15 15:26:23.845 Error code: 8
. 2007-06-15 15:26:23.845 Error message from server (en): The request is not supported.
. 2007-06-15 15:26:23.845 Request code: 9")
* 2007-06-15 15:26:26.501 (EScpSkipFile) Upload of file 'Alt120.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists,
* 2007-06-15 15:26:26.501 The server does not support the operation.
* 2007-06-15 15:26:26.501 Error code: 8
* 2007-06-15 15:26:26.501 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:26.501 Request code: 9
. 2007-06-15 15:26:26.501 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\ION212.xls"
. 2007-06-15 15:26:26.517 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\ION212.xls" to remote directory started.
. 2007-06-15 15:26:26.704 Binary transfer mode selected.
. 2007-06-15 15:26:26.704 Checking existence of file.
> 2007-06-15 15:26:26.704 Type: SSH_FXP_LSTAT, Size: 45, Number: 1030407
< 2007-06-15 15:26:26.704 Type: SSH_FXP_ATTRS, Size: 112, Number: 1030407
. 2007-06-15 15:26:26.704 Checking existence of partially transfered file.
> 2007-06-15 15:26:26.704 Type: SSH_FXP_LSTAT, Size: 54, Number: 1030663
< 2007-06-15 15:26:26.720 Type: SSH_FXP_STATUS, Size: 62, Number: 1030663
< 2007-06-15 15:26:26.720 Status/error code: 2
> 2007-06-15 15:26:26.720 Type: SSH_FXP_REMOVE, Size: 41, Number: 1030925
< 2007-06-15 15:26:26.720 Type: SSH_FXP_STATUS, Size: 34, Number: 1030925
< 2007-06-15 15:26:26.720 Status/error code: 0
. 2007-06-15 15:26:26.720 Opening remote file.
> 2007-06-15 15:26:26.720 Type: SSH_FXP_OPEN, Size: 67, Number: 1031171
< 2007-06-15 15:26:26.720 Type: SSH_FXP_HANDLE, Size: 13, Number: 1031171
> 2007-06-15 15:26:27.282 Type: SSH_FXP_WRITE, Size: 16380, Number: 1031686
. 2007-06-15 15:26:30.876 338 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:26:30.876 Type: SSH_FXP_CLOSE, Size: 13, Number: 1075716
< 2007-06-15 15:26:30.892 Type: SSH_FXP_STATUS, Size: 34, Number: 1074438
< 2007-06-15 15:26:30.907 Type: SSH_FXP_STATUS, Size: 34, Number: 1074694
< 2007-06-15 15:26:30.923 Type: SSH_FXP_STATUS, Size: 34, Number: 1074950
< 2007-06-15 15:26:30.939 Type: SSH_FXP_STATUS, Size: 34, Number: 1075206
< 2007-06-15 15:26:30.939 Type: SSH_FXP_STATUS, Size: 34, Number: 1075462
< 2007-06-15 15:26:30.939 Type: SSH_FXP_STATUS, Size: 34, Number: 1075716
< 2007-06-15 15:26:30.939 Status/error code: 0
> 2007-06-15 15:26:30.939 Type: SSH_FXP_RENAME, Size: 86, Number: 1075986
< 2007-06-15 15:26:30.954 Type: SSH_FXP_STATUS, Size: 34, Number: 1075986
< 2007-06-15 15:26:30.954 Status/error code: 0
> 2007-06-15 15:26:30.954 Type: SSH_FXP_SETSTAT, Size: 66, Number: 1031433
< 2007-06-15 15:26:30.954 Type: SSH_FXP_STATUS, Size: 49, Number: 1031433
< 2007-06-15 15:26:30.954 Status/error code: 8, Message: 1031433, Server: The request is not supported. , Language: en
* 2007-06-15 15:26:30.954 (ETerminal) The server does not support the operation.
* 2007-06-15 15:26:30.954 Error code: 8
* 2007-06-15 15:26:30.954 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:30.954 Request code: 9
. 2007-06-15 15:26:30.954 Asking user:
. 2007-06-15 15:26:30.954 Upload of file 'ION212.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore
. 2007-06-15 15:26:30.954 Error code: 8
. 2007-06-15 15:26:30.954 Error message from server (en): The request is not supported.
. 2007-06-15 15:26:30.954 Request code: 9")
* 2007-06-15 15:26:33.860 (EScpSkipFile) Upload of file 'ION212.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists,
* 2007-06-15 15:26:33.860 The server does not support the operation.
* 2007-06-15 15:26:33.860 Error code: 8
* 2007-06-15 15:26:33.860 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:33.860 Request code: 9
. 2007-06-15 15:26:33.860 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Kaiser324.xls"
. 2007-06-15 15:26:33.876 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Kaiser324.xls" to remote directory started.
. 2007-06-15 15:26:34.032 Binary transfer mode selected.
. 2007-06-15 15:26:34.032 Checking existence of file.
> 2007-06-15 15:26:34.032 Type: SSH_FXP_LSTAT, Size: 48, Number: 1076231
< 2007-06-15 15:26:34.048 Type: SSH_FXP_ATTRS, Size: 112, Number: 1076231
. 2007-06-15 15:26:34.048 Checking existence of partially transfered file.
> 2007-06-15 15:26:34.048 Type: SSH_FXP_LSTAT, Size: 57, Number: 1076487
< 2007-06-15 15:26:34.048 Type: SSH_FXP_STATUS, Size: 62, Number: 1076487
< 2007-06-15 15:26:34.048 Status/error code: 2
> 2007-06-15 15:26:34.048 Type: SSH_FXP_REMOVE, Size: 44, Number: 1076749
< 2007-06-15 15:26:34.048 Type: SSH_FXP_STATUS, Size: 34, Number: 1076749
< 2007-06-15 15:26:34.048 Status/error code: 0
. 2007-06-15 15:26:34.048 Opening remote file.
> 2007-06-15 15:26:34.048 Type: SSH_FXP_OPEN, Size: 70, Number: 1076995
< 2007-06-15 15:26:34.064 Type: SSH_FXP_HANDLE, Size: 13, Number: 1076995
> 2007-06-15 15:26:34.064 Type: SSH_FXP_WRITE, Size: 16380, Number: 1077510
. 2007-06-15 15:26:48.532 1292 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:26:48.532 Type: SSH_FXP_CLOSE, Size: 13, Number: 1243652
< 2007-06-15 15:26:48.548 Type: SSH_FXP_STATUS, Size: 34, Number: 1242374
< 2007-06-15 15:26:48.563 Type: SSH_FXP_STATUS, Size: 34, Number: 1242630
< 2007-06-15 15:26:48.579 Type: SSH_FXP_STATUS, Size: 34, Number: 1242886
< 2007-06-15 15:26:48.594 Type: SSH_FXP_STATUS, Size: 34, Number: 1243142
< 2007-06-15 15:26:48.610 Type: SSH_FXP_STATUS, Size: 34, Number: 1243398
< 2007-06-15 15:26:48.610 Type: SSH_FXP_STATUS, Size: 34, Number: 1243652
< 2007-06-15 15:26:48.610 Status/error code: 0
> 2007-06-15 15:26:48.610 Type: SSH_FXP_RENAME, Size: 92, Number: 1243922
< 2007-06-15 15:26:48.610 Type: SSH_FXP_STATUS, Size: 34, Number: 1243922
> 2007-06-15 15:26:48.610 Type: SSH_FXP_SETSTAT, Size: 69, Number: 1077257
< 2007-06-15 15:26:48.610 Type: SSH_FXP_STATUS, Size: 49, Number: 1077257
< 2007-06-15 15:26:48.610 Status/error code: 8, Message: 1077257, Server: The request is not supported. , Language: en
* 2007-06-15 15:26:48.610 (ETerminal) The server does not support the operation.
* 2007-06-15 15:26:48.610 Error code: 8
* 2007-06-15 15:26:48.610 Error message from server (en): The request is not supported.
* 2007-06-15 15:26:48.610 Request code: 9
. 2007-06-15 15:26:49.063 Asking user:
. 2007-06-15 15:26:49.063 Upload of file 'Kaiser324.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on
. 2007-06-15 15:26:49.063 Error code: 8
. 2007-06-15 15:26:49.063 Error message from server (en): The request is not supported.
. 2007-06-15 15:26:49.063 Request code: 9")
* 2007-06-15 15:27:05.157 (EScpSkipFile) Upload of file 'Kaiser324.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists,
* 2007-06-15 15:27:05.157 The server does not support the operation.
* 2007-06-15 15:27:05.157 Error code: 8
* 2007-06-15 15:27:05.157 Error message from server (en): The request is not supported.
* 2007-06-15 15:27:05.157 Request code: 9
. 2007-06-15 15:27:05.157 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\StIvesNL842.xls"
. 2007-06-15 15:27:05.157 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\StIvesNL842.xls" to remote directory started.
. 2007-06-15 15:27:05.282 Binary transfer mode selected.
. 2007-06-15 15:27:05.282 Checking existence of file.
> 2007-06-15 15:27:05.282 Type: SSH_FXP_LSTAT, Size: 50, Number: 1244167
< 2007-06-15 15:27:05.297 Type: SSH_FXP_ATTRS, Size: 112, Number: 1244167
. 2007-06-15 15:27:05.297 Checking existence of partially transfered file.
> 2007-06-15 15:27:05.297 Type: SSH_FXP_LSTAT, Size: 59, Number: 1244423
< 2007-06-15 15:27:05.297 Type: SSH_FXP_STATUS, Size: 62, Number: 1244423
< 2007-06-15 15:27:05.297 Status/error code: 2
> 2007-06-15 15:27:05.297 Type: SSH_FXP_REMOVE, Size: 46, Number: 1244685
< 2007-06-15 15:27:05.297 Type: SSH_FXP_STATUS, Size: 34, Number: 1244685
< 2007-06-15 15:27:05.297 Status/error code: 0
. 2007-06-15 15:27:05.297 Opening remote file.
> 2007-06-15 15:27:05.297 Type: SSH_FXP_OPEN, Size: 72, Number: 1244931
< 2007-06-15 15:27:05.313 Type: SSH_FXP_HANDLE, Size: 13, Number: 1244931
> 2007-06-15 15:27:05.328 Type: SSH_FXP_WRITE, Size: 16380, Number: 1245446
. 2007-06-15 15:27:18.297 1214 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:27:18.297 Type: SSH_FXP_CLOSE, Size: 13, Number: 1401604
< 2007-06-15 15:27:18.312 Type: SSH_FXP_STATUS, Size: 34, Number: 1400326
< 2007-06-15 15:27:18.328 Type: SSH_FXP_STATUS, Size: 34, Number: 1400582
< 2007-06-15 15:27:18.359 Type: SSH_FXP_STATUS, Size: 34, Number: 1400838
< 2007-06-15 15:27:18.375 Type: SSH_FXP_STATUS, Size: 34, Number: 1401094
< 2007-06-15 15:27:18.391 Type: SSH_FXP_STATUS, Size: 34, Number: 1401350
< 2007-06-15 15:27:18.391 Type: SSH_FXP_STATUS, Size: 34, Number: 1401604
< 2007-06-15 15:27:18.391 Status/error code: 0
> 2007-06-15 15:27:18.391 Type: SSH_FXP_RENAME, Size: 96, Number: 1401874
< 2007-06-15 15:27:18.391 Type: SSH_FXP_STATUS, Size: 34, Number: 1401874
> 2007-06-15 15:27:18.391 Type: SSH_FXP_SETSTAT, Size: 71, Number: 1245193
< 2007-06-15 15:27:18.406 Type: SSH_FXP_STATUS, Size: 49, Number: 1245193
< 2007-06-15 15:27:18.406 Status/error code: 8, Message: 1245193, Server: The request is not supported. , Language: en
* 2007-06-15 15:27:18.406 (ETerminal) The server does not support the operation.
* 2007-06-15 15:27:18.406 Error code: 8
* 2007-06-15 15:27:18.406 Error message from server (en): The request is not supported.
* 2007-06-15 15:27:18.406 Request code: 9
. 2007-06-15 15:27:18.406 Asking user:
. 2007-06-15 15:27:18.406 Upload of file 'StIvesNL842.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on
. 2007-06-15 15:27:18.406 Error code: 8
. 2007-06-15 15:27:18.406 Error message from server (en): The request is not supported.
. 2007-06-15 15:27:18.406 Request code: 9")
* 2007-06-15 15:28:45.201 (EScpSkipFile) Upload of file 'StIvesNL842.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem
* 2007-06-15 15:28:45.201 The server does not support the operation.
* 2007-06-15 15:28:45.201 Error code: 8
* 2007-06-15 15:28:45.201 Error message from server (en): The request is not supported.
* 2007-06-15 15:28:45.201 Request code: 9
. 2007-06-15 15:28:45.201 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\StIvesUK834.xls"
. 2007-06-15 15:28:45.201 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\StIvesUK834.xls" to remote directory started.
. 2007-06-15 15:28:45.310 Binary transfer mode selected.
. 2007-06-15 15:28:45.310 Checking existence of file.
> 2007-06-15 15:28:45.310 Type: SSH_FXP_LSTAT, Size: 50, Number: 1402119
< 2007-06-15 15:28:45.326 Type: SSH_FXP_ATTRS, Size: 112, Number: 1402119
. 2007-06-15 15:28:45.326 Checking existence of partially transfered file.
> 2007-06-15 15:28:45.326 Type: SSH_FXP_LSTAT, Size: 59, Number: 1402375
< 2007-06-15 15:28:45.326 Type: SSH_FXP_STATUS, Size: 62, Number: 1402375
< 2007-06-15 15:28:45.326 Status/error code: 2
> 2007-06-15 15:28:45.326 Type: SSH_FXP_REMOVE, Size: 46, Number: 1402637
< 2007-06-15 15:28:45.326 Type: SSH_FXP_STATUS, Size: 34, Number: 1402637
< 2007-06-15 15:28:45.326 Status/error code: 0
. 2007-06-15 15:28:45.326 Opening remote file.
> 2007-06-15 15:28:45.326 Type: SSH_FXP_OPEN, Size: 72, Number: 1402883
< 2007-06-15 15:28:45.341 Type: SSH_FXP_HANDLE, Size: 13, Number: 1402883
> 2007-06-15 15:28:45.357 Type: SSH_FXP_WRITE, Size: 16380, Number: 1403398
. 2007-06-15 15:28:57.638 1214 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:28:57.638 Type: SSH_FXP_CLOSE, Size: 13, Number: 1559556
< 2007-06-15 15:28:57.638 Type: SSH_FXP_STATUS, Size: 34, Number: 1558278
< 2007-06-15 15:28:57.654 Type: SSH_FXP_STATUS, Size: 34, Number: 1558534
< 2007-06-15 15:28:57.669 Type: SSH_FXP_STATUS, Size: 34, Number: 1558790
< 2007-06-15 15:28:57.701 Type: SSH_FXP_STATUS, Size: 34, Number: 1559046
< 2007-06-15 15:28:57.701 Type: SSH_FXP_STATUS, Size: 34, Number: 1559302
< 2007-06-15 15:28:57.701 Type: SSH_FXP_STATUS, Size: 34, Number: 1559556
< 2007-06-15 15:28:57.701 Status/error code: 0
> 2007-06-15 15:28:57.701 Type: SSH_FXP_RENAME, Size: 96, Number: 1559826
< 2007-06-15 15:28:57.716 Type: SSH_FXP_STATUS, Size: 34, Number: 1559826
< 2007-06-15 15:28:57.716 Status/error code: 0
> 2007-06-15 15:28:57.716 Type: SSH_FXP_SETSTAT, Size: 71, Number: 1403145
< 2007-06-15 15:28:57.716 Type: SSH_FXP_STATUS, Size: 49, Number: 1403145
< 2007-06-15 15:28:57.716 Status/error code: 8, Message: 1403145, Server: The request is not supported. , Language: en
* 2007-06-15 15:28:57.716 (ETerminal) The server does not support the operation.
* 2007-06-15 15:28:57.716 Error code: 8
* 2007-06-15 15:28:57.716 Error message from server (en): The request is not supported.
* 2007-06-15 15:28:57.716 Request code: 9
. 2007-06-15 15:28:57.716 Asking user:
. 2007-06-15 15:28:57.716 Upload of file 'StIvesUK834.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on
. 2007-06-15 15:28:57.716 Error code: 8
. 2007-06-15 15:28:57.716 Error message from server (en): The request is not supported.
. 2007-06-15 15:28:57.716 Request code: 9")
* 2007-06-15 15:29:09.638 (EScpSkipFile) Upload of file 'StIvesUK834.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem
* 2007-06-15 15:29:09.638 The server does not support the operation.
* 2007-06-15 15:29:09.638 Error code: 8
* 2007-06-15 15:29:09.638 Error message from server (en): The request is not supported.
* 2007-06-15 15:29:09.638 Request code: 9
. 2007-06-15 15:29:09.638 File: "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Topac451.xls"
. 2007-06-15 15:29:09.638 Copying "F:\xxxx\Quotation and MI System\Reporting\Clone\testing\Topac451.xls" to remote directory started.
. 2007-06-15 15:29:09.747 Binary transfer mode selected.
. 2007-06-15 15:29:09.747 Checking existence of file.
> 2007-06-15 15:29:09.747 Type: SSH_FXP_LSTAT, Size: 47, Number: 1560071
< 2007-06-15 15:29:09.763 Type: SSH_FXP_ATTRS, Size: 112, Number: 1560071
. 2007-06-15 15:29:09.763 Checking existence of partially transfered file.
> 2007-06-15 15:29:09.763 Type: SSH_FXP_LSTAT, Size: 56, Number: 1560327
< 2007-06-15 15:29:09.778 Type: SSH_FXP_STATUS, Size: 62, Number: 1560327
< 2007-06-15 15:29:09.778 Status/error code: 2
> 2007-06-15 15:29:09.778 Type: SSH_FXP_REMOVE, Size: 43, Number: 1560589
< 2007-06-15 15:29:09.794 Type: SSH_FXP_STATUS, Size: 34, Number: 1560589
< 2007-06-15 15:29:09.794 Status/error code: 0
. 2007-06-15 15:29:09.794 Opening remote file.
> 2007-06-15 15:29:09.794 Type: SSH_FXP_OPEN, Size: 69, Number: 1560835
< 2007-06-15 15:29:09.810 Type: SSH_FXP_HANDLE, Size: 13, Number: 1560835
> 2007-06-15 15:29:09.810 Type: SSH_FXP_WRITE, Size: 16380, Number: 1561350
. 2007-06-15 15:29:12.731 122 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2007-06-15 15:29:12.731 Type: SSH_FXP_CLOSE, Size: 13, Number: 1577732
< 2007-06-15 15:29:12.763 Type: SSH_FXP_STATUS, Size: 34, Number: 1576454
< 2007-06-15 15:29:12.794 Type: SSH_FXP_STATUS, Size: 34, Number: 1576710
< 2007-06-15 15:29:12.841 Type: SSH_FXP_STATUS, Size: 34, Number: 1576966
< 2007-06-15 15:29:12.872 Type: SSH_FXP_STATUS, Size: 34, Number: 1577222
< 2007-06-15 15:29:12.888 Type: SSH_FXP_STATUS, Size: 34, Number: 1577478
< 2007-06-15 15:29:12.888 Type: SSH_FXP_STATUS, Size: 34, Number: 1577732
< 2007-06-15 15:29:12.888 Status/error code: 0
> 2007-06-15 15:29:12.888 Type: SSH_FXP_RENAME, Size: 90, Number: 1578002
< 2007-06-15 15:29:12.903 Type: SSH_FXP_STATUS, Size: 34, Number: 1578002
< 2007-06-15 15:29:12.903 Status/error code: 0
> 2007-06-15 15:29:12.903 Type: SSH_FXP_SETSTAT, Size: 68, Number: 1561097
< 2007-06-15 15:29:12.919 Type: SSH_FXP_STATUS, Size: 49, Number: 1561097
< 2007-06-15 15:29:12.919 Status/error code: 8, Message: 1561097, Server: The request is not supported. , Language: en
* 2007-06-15 15:29:12.919 (ETerminal) The server does not support the operation.
* 2007-06-15 15:29:12.919 Error code: 8
* 2007-06-15 15:29:12.919 Error message from server (en): The request is not supported.
* 2007-06-15 15:29:12.919 Request code: 9
. 2007-06-15 15:29:12.919 Asking user:
. 2007-06-15 15:29:12.919 Upload of file 'Topac451.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore
. 2007-06-15 15:29:12.919 Error code: 8
. 2007-06-15 15:29:12.919 Error message from server (en): The request is not supported.
. 2007-06-15 15:29:12.919 Request code: 9")
* 2007-06-15 15:29:16.513 (EScpSkipFile) Upload of file 'Topac451.xls' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists,
* 2007-06-15 15:29:16.513 The server does not support the operation.
* 2007-06-15 15:29:16.513 Error code: 8
* 2007-06-15 15:29:16.513 Error message from server (en): The request is not supported.
* 2007-06-15 15:29:16.513 Request code: 9
. 2007-06-15 15:29:16.513 Listing directory "/XYZ_Upload/testing".
> 2007-06-15 15:29:16.513 Type: SSH_FXP_OPENDIR, Size: 30, Number: 1578251
< 2007-06-15 15:29:16.528 Type: SSH_FXP_HANDLE, Size: 13, Number: 1578251
> 2007-06-15 15:29:16.528 Type: SSH_FXP_READDIR, Size: 13, Number: 1578508
< 2007-06-15 15:29:16.544 Type: SSH_FXP_NAME, Size: 502, Number: 1578508
> 2007-06-15 15:29:16.544 Type: SSH_FXP_READDIR, Size: 13, Number: 1578764
< 2007-06-15 15:29:16.559 Type: SSH_FXP_STATUS, Size: 44, Number: 1578764
< 2007-06-15 15:29:16.559 Status/error code: 1
> 2007-06-15 15:29:16.559 Type: SSH_FXP_CLOSE, Size: 13, Number: 1579012
Your comments would be appreciated
regards
B
Client:
Server:
Compression = No
FULL LOG
regards
B
Site Admin -
- 42,786
- Prague, Czechia
Re: error occured while setting the permissions and/or timestamp
You have disabled option "preserve timestamp", but not not "set permissions". Unless you are using synchronize command, which forces the "preserve timestamp", because it won't work without it.I can understand the part where it says "the server does not support the operation", but I'm confused about why the client is asking the server to do anything with timestamp or permission when both options are explicitly disabled.
Only if the server replies "access denied". But it replies "operation not supported".Also, shouldn't the option to 'ignore permissions errors' cause such a condition to be handled gracefully??
- Guest
i've tried every combination of upload settings, and i'm unable to upload/replace without encountering the dialogue box after each transfer.
Can you suggest anything i might try to resolve the problem?
Out of curiosity, I tried the same thing with FileZilla and it works ok, but there are a number of features FileZilla doesnt have which WinSCP does. Suffice to say I'd like to continue to use WinSCP.
Any suggestions?
thanks in advance.
B
Any suggestions?
thanks in advance.
B
Site Admin -
First, can you confirm my assumption that you use synchronization?
- Guest
no - i'm not using sync in this case. I'm just dragging and dropping files from local to remote path
Site Admin -
OK, so than make sure that "set permissions" is off before transfer.
