Download Files from Directory with Spaces in Batch
reiibs
Austria
I had read the Post "CD to Directory with Spaces", but this didn't solves my problem.
I want to download only Files from a directory without subdirs. I tried the following command: winscp3.com user@host /command "option exclude */" "get /dir/dir with spaces/" Exit and the error message says "Can't get attributes for file '/dir/dir' and also permission denied.
How can i solve that or is it not possible. If i must not use a scriptfile it would be absolutly great.
Many Thanks
Reinhard
Re: Download Files from Directory with Spaces in Batch
Do to limitations of command-line parsing on Windows, you cannot do that. You need to use script file.
reiibs
Austria
I found an other solution. When you use "echo get "Sourcepath" "Destionationpath" | Winscp3.com than its working.
If details are needed please write me a note.
Regards
Reinhard
