Clarification Regarding correct Borland C++ Builder version
C2Z4S9
In the readme file included with the source code you specify a build requirement of:
To build WinSCP you need Borland C++ Builder 6.
In these forums, you have stated that you need at least the "Professional" version. I just wanted to see if this was really the case. This will not build using Borland C++ Builder 6 Personal?
Re: Clarification Regarding correct Borland C++ Builder version
WinSCP should build with any version of Borland C++ Builder 6.
Zhou
RE
C2Z4S9 wrote:
Thank you for the information. I can now confirm that WinScp will build on Borland C++ Builder Personal. I built it without any problems.
I tried to build the 4.0 source code using Builder Personal. However, it fails. It says that it can't open afx.h.
Do you know why?
Re: RE
Please follow here.
