Way to automatically preserve file format?
jæger
I have a lot of files I edit on my Linux server, and some are in PC format while others are in UNIX format. Is there a way to have WinSCP automatically detect which format a file is in and not mess with that? I'd rather not have to check which format a particular file is in and then check the EOL environment settings, and change them if necessary, for each file I might want to edit. Thx
Re: Way to automatically preserve file format?
WinSCP cannot automatically detect that. But it can detect that by file extension (or maybe directory where the file is stored), if it helps you.
