Backup files command
feedel
Hi!
I'm a new user to WinSCP and will probably stick to it - rocks.
Maybe you'll help to write a bash/winscp script/command so I could do this:
- right click on a remote directory
- select 'backup directory' option
- enter destination directory name
- and now files from selected directory are being packed and downloaded to selected destination/local directory.
Is it possible to run automatic download after some action at all?
Kuba
Re: Backup files command
You cannot launch automatic download from GUI. You can write a script for that. But you would have to modify the source directory in it each time. Or write another script to do that for you.
