How can I set compression option for transferring a file ?
lindascott
Can I transfer a file with a compression option on to the non-ssh server ? If I can, then where I can set the compression option in WinSCP window ?
Thanks.
LS.
Re: How can I set compression option for transferring a file ?
What is non-SSH server? FTP server? You cannot connect with WinSCP to non-SSH server.
With WinSCP you can enable compression only for whole session, not for one particular file transfer. See "SSH" tab of login dialog.
