Uploading multiple files with script
Ulrike
i'm uploading multiple files via script to one SFTP server. Each file is done with one script. After uploading 5 files (running 5 scripts) the login to the server is not possible for the next 2 or 3 minutes.
option batch on
open sftp://<user>:<pw>@<ip>:<port>
session
option transfer binary
put <file>
Any suggestions?
Regards,
Ulrike
RickB
Australia
Re: Uploading multiple files with script
The simplest (but not most elegant) solution is to list all files in the one script:
option batch on
session
put <file1>
put <file2>
put <file3>
put <file4>
put <file5>
put <file6>
put <file7>
But why don't you use a wildcard instead? For example, if all the files you are uploading share the same extension (for example .txt) you could do this:
put *.txt
There are other examples here:
https://winscp.net/eng/docs/scriptcommand_put
Ulrike
thanks for the reply.
The reason for uploading the files one by one is to make sure that every and each file succeeded. I'm writing the script for the upload from code. And I can only get the return code from the whole script (as far as I know). As there are multiple formats files in multiple destinations wildcards won't work. :(
Any suggestions? Is this a known behaviour?
Regards,
Ulrike
It seems like you have some connection limit set on your server.
