Problem with connection
clientvoip
I have written my first script, but he doesn't work correctly.
The script run on Windows XP PC, I want connect to remote machine (with Fedora 5.0)
The script is:
option batch on
open root@IP_addr_Fedora_machine
pwd
ls
close
From an open console windows, I write
winscp3.com /console /C:\Document and Setting\user\Desktop\script=scriptSCP3.scp
The script ask me user name, I specified it and the output is
HOST DOESN NOT EXIST
Could someone help me?
Thanks in advance
Re: Problem with connection
This looks strange. Should it be:
winscp3.com /console /script=C:\Document and Setting\user\Desktop\scriptSCP3.scp
chessys
User Name prompt
I am also being asked for a "user name" when using the /command line. Here is my batch file...
option batch on
open name@host.com
cd /home/exportfiles/
option transfer binary
put D:\*
Here is my command line...
"C:\Program Files\WinSCP3\WinSCP3.com" /console /script= D:\Exportfiles.txt
The open command is set for a stored session however I tried to use the name:password@host option with the same results. I'm successfully using a similiar batch file but using the "get" command instead of "put" and with the same saved session.
Thanks in advance for assistance.
Re: User Name prompt
option batch on
open name@host.com
put D:\*
So with "get" you are not prompted for password?
