download only files
reiibs
Austria
download only files
I want to try to download only files from a given directory but i found no documentation about that. Is that possible without enum the files and download file by file?
Regards
Reinhard
reiibs
Austria
Thats not working. When i use the command winscp3.com user@host /command "get /path/subdir/*.* D:\test\" i get an Error saying that "D:\test\" is not a file. The Directory D:\test exists. When i add *.* to the Destionationpath it will download all files and Subdirectories. Thats not what i want.
Regards
Reinhard
1) There's no need to add "*.*" to the and of destination path. It just have to end with backslash.
2) Use "option exclude */" to omit all directories.
