Windows Service calling WinSCP
Blueeyes
I have a problem, here is the scenario, I have a windows service checking a few directories and when finding new files makes some operations on those files. Once all the operation are performed I need to upload those file on the main server via SCP. I have a console program doing it perfectly, but when passing in console mode it crashes.
Anybody got this problem, or has a workaround for it.
Thanks in advance.
Re: Windows Service calling WinSCP
Does it really crash or just fail to do what you want it to do? :-)
If the latter is true, this FAQ may help you.
