Automatic synchronizing
Hendrikdegraaf
Holland
I have a feeling that this is a really stupid question, but I've looked for ages and I can't find wat I am looking for.
I want to create a script that does the following:
Start WinSCP
Start a stored session
Synchronize local [local docs] [docs on server]
or,
The script starts when I start WinSCP
I hope someone can help, because I really don't get the terminal: it sais I have to work on a seperate shell. Also I don't get the scrips on the website: it seems that many of them are scripts that start other scrips, which all seems a little farfetched.
I'm looking forward to hearing from someone.
Kind regards,
Hendrik
Re: Automatic synchronizing
Start WinSCP
script.txt:
open stored_session
synchronize local [local docs] [docs on server]
script.bat
winscp3.exe /console /script=script.txt
AMK
Syncronization
I am using a WinSCP sync script in conjunction with Windows Task Scheduler. When a sync occurs and a new local file is identified, are the entire contents of the file added to the remote server or just the new parts. The reason I ask is the files on the local server become quite large (~100MB) and we have about 15 local files that change about once an hour. If the sync is copying the entire contents at each sync, we're going to kill our T1 line.
Can you advise on this matter?
bdornbush
Santa Rosa, CA
My script to do this
I had a similar need, and after reading through the site, I arrived at this script which allows me to synchronize the files from a remote server to my local PC. I do this so that I have a copy of the most recent backups from my server to my PC.
I was delighted to find WinSCP as it allows me to do secure transfers between my server and my local PC, which I consider to be essential.
I have a directory on my server named "backups." In this directory, I have another directory, "archives" which holds the files that I want to copy. In "backups," I also have the script files to do my backups.
My script was derived from some I found on this site. At first, I planned to copy files from my server to my local PC, but then I found "synchronize" and this works better for me as it only copies the new files, that is, the most recent backups. I left the copy commands for reference. The script is:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect
open user@server.org
# Change remote directory
cd backups
# Force binary mode transfer
option transfer binary
# Download file to the local directory
# get archives/* f:\backups\archives\*
# Delete downloaded files
# rm archives/*
# sync from remote to local
synchronize local f:\backups\archives archives
# Exit WinSCP
I used Windows XP Scheduled Tasks to run this program weekly, a few hours after the backup is generated on the server. The command I used in Scheduled Tasks is:
C:\PROGRA~1\WinSCP\WinSCP.exe /console /script=f:\backups\download.txt /log=f:\backups\winscp.txt
This command runs WinSCP and uses the script "download.txt" and logs the results to "winscp.txt" These files are on my F: drive in the backups directory.
I hope that this script is useful to others.
Re: Syncronization
Entire file content is transferred, as there's no way for WinSCP to verify that contents of the two files matches (apart from downloading the whole file of course :-))
mixersoft
Re: script dies on open session
script.txt:
open stored_session
I'm trying to follow this exactly, but when I run the open command, I always get an interactive window to choose the saved session, and the script seems to die. This is what I am using:
option batch on
# Connect
open session_name
What am I doing wrong?[/code]
AlphaUno
Nashville, TN
Trying to find the best feed to post this
Hi I am wanting to create some script that will move all the files from an one of my servers to another. This is going to be used for backup purposes and run often.
I see the synchronization is the way to go and I have easily created some batch files that will do this with winscp.
However my problem lies in that I don't want all files from that folder moved only ones with the a file name that begins with "cl"
Here is my code.
open asp1_checks
pause
synchronize -filemask="cl.*" local "Y:\checks\" "/asp1/luminx/naa/live/jacob/checks/"
Re: I cannot get a synchronization script to work!
YIKES. I butchered that. Let me try again:
I've tried many different example scripts and none of them seem to work for me. Can someone help me troubleshoot?
The most recent attempt, straight from the example scripts:
bat:
winscp.com /script=script.txt /parameter // %1 "/internet/remotedirectory/%~n1%~x1"
txt:
# Being intended for interactive session, we are not enabling batch mode
# Connect
open sftp://user:pword@sftp.address.gov -hostkey="ssh-rsa 1024 9c:b7:21:5c:ad:02:bb:30:c5:27:a5:bc:41:1a:ab:a0"
# Synchronize paths provided via environment variables
synchronize remote "%1%" "%2%"
I run this bat file and the window closes at: Authenticating with pre-entered password.
What I really want to do is synchronize the local folder to the remote folder, but for the sake of learning, I'm just trying to get any script working.
Previously, I had tried:
option batch abort
synchronize local H:\LocalDirectory /internet/remotedirectory
bat:
Your duplicate post on superuser.com:
https://stackoverflow.com/q/33680432/850848
The same answer:
Your script is generally correct. But we need to see a log file to help you. Add /log=c:\path\winscp.log to command-line.
MCG
Access Problem
I have connected my ftp server and my aim is to get my camera records from there to my desktop.
I have already thicked Passive Mode.
When I tried to access my records in there, I got this error on my screen.
Error Listing Directory "X"
Invalid path specified"
By the way, when I clicked on the file and push the "Calculate" button it shows that there are X files and they hold X size in disk.
When I examined the permission options, all of them are not thicked initially. When I wanted to change them it also gave this error.
Cannot change properties of file. Unknown command SITE"
Another interesting this is that I have already accessed all of my files with Filezilla.
Do you have any solution for this problem ?
Thanks a lot.
MCG
Re: Access Problem
CWD /110/
250 CWD command successful.
PWD
257 "/110/"
TYPE A
200 Type A Accepted
PASV
227 Entering Passive Mode (x,x,x,x,27,89) ..
LOST
Connecting to x.x.x.x:7000
125 Connected, Starting Data Transfer..
<Empty Directory Listing>
550 Invalid path specified
(ECommand) Error listing directory "110".
Invalid path specified.
This is the log file.
It says its invalid path but i have already accessed this path from filezilla.
Thanks for reply.
Re: Access Problem
No this is not a log file.
A log file from FileZilla would be helpful too.
bmwlover
Cant' get files
I have video files in one server which is ftp server.
I have already list directories and video files using winscp script. These video files seems that have no file extension. When I got the video files list, I saw that "name" there is no file extension like .mpeg or whatever it is.
I tried to get this file and I wrote this code:
get /myDirectory/myVideoFile and it said to me this file/folder is not found
get /myDirectory/myVideoFile.* and it also said to me this file is not found.
* shows that i tried all possible video file extension.
Do you have any idea to solve this problem ?
Thanks.
Re: Cant' get files
Your code looks ok. Can you download the file anyhow? In GUI? Or in other FTP client?
bmwlover
Re: Cant' get files
Yes.
I can download this file from Filezilla obviously and also can play and download in GUI.
I don't know what is going wrong.
Re: Cant' get files
So show us a log from the GUI please.
pankaj1111
atomatic synchronization
option batch on
open CSBJ01@efg.hdfcbank.com
cd backups
get /Shree_Samarth_Sah_Bank_ltd* E:\testlocal*
synchronize local E:\testlocal Shree_Samarth_Sah_Bank_ltd
sir this my code or script but it doenst work and Shree_Samarth_Sah_Bank_ltd this is the folder on my server and i have to get it on my local computer when computer is on so pls do
Re: atomatic synchronization
Please start a new thread for your problem. In the new thread, describe what does it mean "it doenst work". What does it do? Do you get any errors? Or wrong behaviour?
Also, why do you use both get and synchronize? It does not make sense.
pankaj1111
Sir i want to atomaticaly copy my remeote server files to my local pc so i have wrrinten this script and i am etering this script in to task scheduler but it does'nt work so help me for this...
I've asked you to start a new thread. You also didn't answer my question.
