overwite files without confirm to overwrite
digital-cipher
Hi all
using winscp.com, what command disables the overwrite confirm and DOES overwrite the file.
ive tried /command "option comfirm off"
This does supress the confirm overwrite but DOES NOT overwrite the file.
Re: overwite files without confirm to overwrite
And what happens instead?
the file is left unchanged, i need to be able to overwrite files without being prompted to overwrite or not.
"excellent software tho"
I cannot imagine how this can be happening. Can you post a log file? For simple case, where synchronization of single file should occur, but does not.
