clovis
Chicago
I'm getting a "Site does not exist" message when I try to connect. Can anyone suggest why this might be :?:
martin ◆
Can you connect with any other SSH client?
thanks for getting back. i really don't know of any other ftp site i can connect to to test this. does it matter that i am trying to connect to a https:// or a dot-tv site :?:
martin ◆
I've meant if you can try other client than WinSCP?
No, WinSCP is the only client installed on my computer at this time.
martin ◆
OK, what do you put into the login box?
