run WinSCP from vbs
Leo
Toronto
run WinSCP from vbs
So I am trying to run a command on WinSCP from VBS, but it does not run. Is there a way to accomplish this?
wshShell.Run("WinSCP3.exe secureSFTP /console /script=fsftp.txt"),1,True
see, when it tries to run the txt file, it closes. Is there a way to make it wait? How can I do this?
Leo
Leo
Toronto
Re: run WinSCP from vbs
never mind. got it
if anyone will benefit from this (and doesn't know how to), here's what I did
From VBS, it seems impossible to run an WinSCP script that resides in a txt file. Therefore this will not work:
Dim wshShell
Set wshShell = WScript.CreateObject("WScript.Shell")
Putting the above code in a bat file and trying to execute the bat file from VBS had the same issue. I tried several techniques but none worked, until this
Dim wshShell
Dim sftpcmd
sftpcmd = "WinSCP3 secureSFTP /console /command " & """option batch on""" & " " & """option confirm off""" & " " & """cd /Dex""" & " " & """option transfer binary""" & " " & """get securefile.txt.pgp C:\\SecureFileDump\\Archive\\""" & " " & """close""" & " " & """exit"""
wshShell.Run(sftpcmd),1,true
wscript.sleep(10000) 'wait for 10 seconds until sftp is done
Maybe this is not a big thing, but I thought I'd put it up here for someone's benefit
Leo
Leo
Have you tried to specify full path? Would it help?
Leo
Toronto
Hi Martin. Yes as a matter of fact I did try that. The problem is not with WinSCP, it's with how WSCRIPT will execute a batch file that in turns executes a program, which in turn takes its commands from a text file. The execution hierarchy is long in this case, and the Test file gets no priority, and there was no (easy) way to get the WinSCP script to open and execute the commands in the .txt file. However as I wrote above, I did find the solution, by directly running the WinSCP script from within the VBS file, and passing the commands through the /command switch. It works perfectly. Thanks for the help
Leo
