Copy files with inherited permissions?
lummi
Hi all,
How can an retain the file and folder permissions when uploading new files to the server? Right now, when I upload files to server I get myself as Owner and Users as group?
But how can I make it to inherite servers permissions?
Or do I have to change the permissions later on via SSH?
But when I replace allready existing files, the permission is correct.
Please if someone knows let me know and thanks for a wonderful product!
Re: Copy files with inherited permissions?
Where the permissions should be inherited from?
lummi
Permission..
Well I thought it was possible to inherite the remote servers permissions.
For example, if I upload files to folder htdocs/somefolder/somefiles.something I would like the files that I have uploaded to "inherite" the permissions.
In this case, owner "www-data" and group somegroup.
Not possible?
Or do I have to change the permissions later on after uploading with chown manually?
Regards,
Lummi
Re: Permission..
Not possible?
It depends on how your server treats the permissions. But WinSCP does not instruct the server in any way, what the owner/group should be like. So if they are not inherited, then your server obviously does not do that.
You may be able to change ownership from WinSCP. See documentation.
