Problems with WinSCP 3.8.2 & Vshell 2.5
pete_rimmer
I have just upgraded from WinSCP 3.7 because I was having issues when trying to overwrite files in VShell 2.5 (failed, but still initiated vshell trigger for original version of file!). Putty psftp command line didn't show the symptoms, so I though I'd try the latest WinSCP. However, I can't even transfer any file up to the VShell Server? Anyone got any ideas?
Vshell server 2.5 running on Solaris 8 2/04. WinSCP 3.8.2 on XP Pro SP2.
Here is session log (logins/server_names/IP's & keys changed for security)
WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 2)
Login time: 09 October 2006 14:39:41
Session name: test_acct@sftp_serv3
Host name: sftp_serv3 (Port: 999)
User name: test_acct (Password: No, Key file: No)
Transfer Protocol: SFTP
SSH protocol version: 2; Compression: No
Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
SSH Bugs: -,-,-,-,-,-,-,-
SFTP Bugs: -,-,-
Proxy: none
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
Looking up host "sftp_serv3"
Connecting to 192.168.1.2 port 999
Server version: SSH-2.0-0.0
We claim version: SSH-2.0-WinSCP_release_3.8.2
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-dss 1024 <<hidden>>
Initialised AES-256 client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "test_acct".
| This system is for the use of authorized users only. |
| Individuals using this computer system without authority, or in |
| excess of their authority, are subject to having all of their |
| activities on this system monitored and recorded by system |
| personnel. |
| In the course of monitoring individuals improperly using this |
| system, or in the course of system maintenance, the activities |
| of authorized users may also be monitored. |
| Anyone using this system expressly consents to such monitoring |
| and is advised that if such monitoring reveals possible |
| evidence of criminal activity, system personnel may provide the |
| evidence of such monitoring to law enforcement officials. |
Session password prompt (test_acct@sftp_serv3's password: )
Asking user for password.
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 388, Number: -1
SFTP version 5 negotiated.
Unknown server extension newline@vandyke.com=0x000000010A
Server requests EOL sequence 0x0A.
Unknown server extension default-fs-attribs@vandyke.com=0x00000003000000012F00000000
Server support information:
Attribute mask: 800003A9, Attribute bits: 0, Open flags: 3F
Access mask: 0, Open block masks: 0, Block masks: 0, Max read size: 32768
Attribute extensions (0)
Extensions (3)
text-seek
version-select
vendor-id
Extensions (3)
text-seek
version-select
vendor-id
Server software: VShell 2.5.0 (build 204) (204) by VanDyke Software, Inc.
SFTP versions supported by the server (VShell format): 3,4,5,6
Type: SSH_FXP_EXTENDED, Size: 63, Number: 200
We will use UTF-8 strings when appropriate
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 272
Type: SSH_FXP_STATUS, Size: 26, Number: 200
Discarding reserved response
Type: SSH_FXP_NAME, Size: 19, Number: 272
Real path is '/'
Listing directory "/".
Type: SSH_FXP_OPENDIR, Size: 10, Number: 523
Type: SSH_FXP_HANDLE, Size: 13, Number: 523
Type: SSH_FXP_READDIR, Size: 13, Number: 780
Type: SSH_FXP_NAME, Size: 356, Number: 780
Type: SSH_FXP_READDIR, Size: 13, Number: 1036
Type: SSH_FXP_STATUS, Size: 44, Number: 1036
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
Startup conversation with host finished.
Detected incoming data while idle
Copying 1 files/directories to remote directory "/"
PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; ClAr: No; ExclM(No):
AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "W:\nsm.txt"
Copying "W:\nsm.txt" to remote directory started.
Ascii transfer mode selected.
Opening remote file.
Type: SSH_FXP_OPEN, Size: 38, Number: 1539
Type: SSH_FXP_STATUS, Size: 34, Number: 1284
Type: SSH_FXP_STATUS, Size: 42, Number: 1539
Status/error code: 8, Message: 1539, Server: Operation not supported, Language: en
Type: SSH_FXP_LSTAT, Size: 21, Number: 1799
Type: SSH_FXP_STATUS, Size: 44, Number: 1799
Status/error code: 2, Message: 1799, Server: No such file or directory, Language: en
(ETerminal) The server does not support the operation.
Error code: 8
Error message from server (en): Operation not supported
Request code: 3
Asking user:
Cannot create remote file '/nsm.txt'. ("The server does not support the operation.
Error code: 8
Request code: 3")
(EScpSkipFile) Cannot create remote file '/nsm.txt'.
Error code: 8
Request code: 3
Type: SSH_FXP_OPENDIR, Size: 10, Number: 2059
Type: SSH_FXP_HANDLE, Size: 13, Number: 2059
Type: SSH_FXP_READDIR, Size: 13, Number: 2316
Type: SSH_FXP_NAME, Size: 356, Number: 2316
Type: SSH_FXP_READDIR, Size: 13, Number: 2572
Type: SSH_FXP_STATUS, Size: 44, Number: 2572
Type: SSH_FXP_CLOSE, Size: 13, Number: 2820
Re: Problems with WinSCP 3.8.2 & Vshell 2.5
Can I have a test accound on your server?
If not, can you try to lower version of SFTP protocol to 4 on SFTP tab of login dialog and try again?
