Save position in editor
Shema
Hello, all!
In the lastest versions of Far (1.70+) and WinSCP (1.51) sometimes editor doesn't save position in files.
While I edit any files on HDD all ok, but while I do it in scp session sometimes (not always but very frequently) position in file drops to file beginning.
In previous versions (Far 170b5, WinSCP 1.4+) bug was absent.
I use SSH/SCP protocol.
Re: Save position in editor
I aware of the bug. But for me it happens for files on HDD as well, so I do not think that it is bug of WinSCP, but rather bug of FAR.
Shema
There is no "save position bug" with files on HDD.
I think this is problem with temporary files... Can plugin control names of temp files? Maybe, projection of remote file to specific file on HDD can solve problem...
There is :-) It may happen less often, but it happens too. I still believe that it is a bug of FAR. It happens approximately since the official 1.70 release. With earlier builds of 1.70 it worked fine.
