Kerberos5/gssapi support?
jskondel
I was excited that winscp and putty both supported socks5 proxy and both worked really well. There is a feature I would like to see implemented and that would be kerberos 5/gssapi support. :wink:
References:
https://www.openssh.com/features.html
NickSz
Kerberos/GSSAPI/Heimdal
when you follow this link <invalid hyperlink removed by admin> you'll find modified code to use kerberos/gssapi/heimdal!
Do you think you will integrate this?
PuTTY is realy great and your sw is the right companion!
Nick
mailto:nicolaie@szabadkai.de
:D
Re: Kerberos/GSSAPI/Heimdal
Thanks for the link. Unfortunatelly, it is based on older version Putty than I'm using. I'll see if I can integrate it. Definitely it would not be in next release.
ggb
As far as I can tell, the latest version of PuTTY is 0.53, and the latest version of PuTTY with GSSAPI and Kerberos from Ceritfied Security Solutions is based on PuTTY 0.53b.
What version of PuTTY are you using?
Thank you.
0.53b is already more than one year old (2002-11-12). I'm using latest development snapshot.
