Catching output of WinSCP /console
theUserWhoLikesScripting
Allemagne
Calling WinSCP from dos window (.. /console /script=...), I can watch the output in a separate dos box, even the (self-generated) shell output of the remote machine.
How can I fix the output to the calling process , no matter if it is a dos window or, like in my case, a java application that integrates WinSCP. (The reason is: I want to interact with the remote application by reading its output)
Is there an appropriate way by using the option-command ?
(Do you support a list of available options ?)
Yours Axel
Re: Catching output of WinSCP /console
If you use the console-interface tool (winscp3.com), you can capture WinSCP output to stardard output.
Allemagne
Hi Martin,
Thanks a lot, it was very easy.
The communication is running.
And what about the option-command ?
A listing of available options would be very nice (As I can only see the examples at the documentation)
Yours Axel
What option-command?
See documentation or "winscp3 /?"
the option-command integrated in the script, for example:
option transfer binary
Yours Axel
See "help option".
