port knocking for security/firewall access
ahz
I'd like to find a way for people at our office to access our Linux file server from home using their Windows computers.
Please implement and integrate a GUI for port knocking. PK adds a simple but effective layer of security.
https://en.wikipedia.org/wiki/Port_knocking
I imagine the PK GUI to be able to use/add/edit/delete a list of port knocking "sequences." Each sequence has one title, one host name, and then an arbitrarily-long, ordered list of port numbers and protocols (TCP or UDP). So, a sequence might be:
Title: The office LAN
Hostname: office.example.com
#1: UDP 12898
#2: TCP 62181
#3: TCP 9999
You could also design the UI for the sequence as a string...e.g.
udp:12898 tcp:62181 tcp:9999
Several applications have integrated port knocking clients. For example, Enhanced TightVNC has it, and it will also be in an upcoming AlmostVPN (for Mac).
zoltan
any news on this?
Is it planned to be implemented, or would it be possible to implement it as a plugin/script/addon/etc?
zoltan wrote:
any news on this?
Nothing new yet.
No it wouldn't.
