Wrong filesize with openssh-server-3.9p1-8.RHEL4.1
faxenoff
FAR Winscp 1.5.1 connected to SFTP openssh-server-3.9p1-8.RHEL4.1 - show wrong filesize of any files. And filecompare function always select all files.
Re: Wrong filesize with openssh-server-3.9p1-8.RHEL4.1
Do you mean that file size shown in panel is different than that of shown in e.g. 'ls -la'?
No. They show equal filesizes. Different filesize in remote panel and local panel. I play with it and discover - only text files change size after upload. (CR+LF transfer fix, i think)
Everytime, I do one simple task - compare remote and local directory. WinSCP show different filesizes (on text files) too, but correct compare files. FarSCP 1.5.1 set all files always different in compare command. This critical bug and need be fixed. 8-(
