Transfer Format #984
monsto
i read the thread at https://winscp.net/forum/viewtopic.php?t=3014
this is exactly the problem i'm having with the additional problem that i can't make it stop.
  • environment tab in the login screen is set to LF (unix)
  • i've set the xfer to text only. (its a perl script)
  • i rclick the file, choose 'edit' and the file downloads then comes up in my editor
  • the original file (pre upload) shows in 2 different editors (ultraedit and pspad) as unix perl
  • uploaded from local to remote, it's unix on the remote.
  • still set as text only, i download the file and it shows in the 2 editors as dos perl
  • a friend downloaded the file using commandline scp command on cygwin
    $ scp -i ssh_keys/blank_id_rsa root@blank.net:/var/www/blank.net/cgi-bin/script.pl .
    and it showed as unix for him
  • removed the default transfer presets, and created a single for Text xfer on condition of remote directory */cgi-bin
  • downloaded a different file in a different dir (robots.txt) with text xfer and it comes down as dos text
  • i was originally using 3.7.4 and upgraded just today no effect.
  • changed to sftp no effect
  • tried drag & drop xfer making sure the dialog has text chosen (it does).
so i need to get files down as unix. am i missing something somewhere?
monsto
someone in another thread wrote:
I am using the 3.8.0 version.
When I transfer files ( scp ) from an Unix system to my Windows station this files are convert to the PC ( DOS ) format.
How can I preserve the Unix format of my transfered files.
this is the problem. i've done everything i listed in my first post to prevent this conversion.
From this, it seems to me that you have forced WinSCP to use text mode transfer, which imply the unix->dos conversion. Just force the binary mode to avoid the conversion.
so let me see if i have this straight...
if there's a text mode transfer, winscp will *automatically* convert from unix to dos for me.
if a script is xferred binary, perl gives a 500 error. if a script has dos line-endings, perl gives a 500 error. i had previously been working with php which doesn't care about either.
it'd be a Good Idea to strip the automatic unix>dos conversion.
Re: checking for update
monsto wrote:
does winscp still do this conversion automatically?
Which conversion? When?
