background transport
-jon-
Hello!
When I send several files or one larger file via background queue mode - at the end of the transfer Servant Salamander freezes. This is not a random feature it happens every time. Files are transfered correct.
I have bought a full Servant Salamander licence.
Any advice?
AIX 5.1 64-bit SSH2 protocol
Thank you.
Best Regards
-jon-
Re: background transport
Can you try to run another instance of Salamander and use help > task list function to break the freezed instance to make it generate bug report?
Daniela
sprava
-jon- wrote:
Done ... check your mailbox.
Let me know.
Thanks a lot.
Best Regards
-jon-
:roll:
dobry den prajem
Pavel
Re: sprava
This has been fixed already. If anyone is still having the problem, please post it here.
Mam stejny problem, kde mohu stahnout novejsi plugin?
Momentalne mam verzi 1.5.1 a mam zakoupenou verzi SS 2.51
Dekuji za odpoved.
Pavel P.
zednik@turnov.org
Re: sprava
Please contact Servant Salamander support at jan.rysavy@altap.cz to get fixed version.
This is also discussed in SS Support forum (<invalid hyperlink removed by admin>).
kaiyara
troy
Yes please do so. If I upload large files (~250MB) to a server I have regulary stops on network errors or server does not respond for x seconds error. This is very annoying, cause all I have to do then is to press ignore or retry. It would do me(us) a great favor, if that would be handled automatically.
_________________
Kaiyara
