- TroyB
- 3
Can you SU to root from a regular user in WinSCP somehow?
I know generally you can't execute commands that require input (root password) but I was wondering if there was any way to pull this off?
Site Admin -
- 43,055
- Prague, Czechia
Re: Can you SU to root from a regular user in WinSCP somehow?
Please read FAQ
Thank you for the response. I still can't get it to work. I edited the
/etc/sudoers and added in the user account as it suggested and now I can do an sudo su and it switches me to root with no prompting for password. But I still can't get it to work within WinSCP. It just times out.
Site Admin -
Can you try to login using PuTTY and specify
/bin/bash -c 'sudo su -' as "Remote command" (on SSH tab)? Would it connect automatically without any prompt? Or post a log file.
Yes, I just did it again and PuTTY works fine and without prompting. I just can't do it in WinSCP.
Site Admin -
Please post a log file.
billguy
Guess I'll pick it up where he left off:
same issue, read the faq, using WinSCP 3.8.2, here's my log:
FWIW I'm on Ubuntu 6.06, my
I am not prompted for a password from the console/putty when I do a
Stumped.
. 2006-09-25 12:28:05.843 Startup conversation with host finished. . 2006-09-25 12:28:17.000 Executing user defined command. > 2006-09-25 12:28:17.000 sudo su ; echo "WinSCP: this is end-of-file:$?" . 2006-09-25 12:28:32.001 Waiting for data timed out, asking user what to do. . 2006-09-25 12:28:32.001 Asking user: . 2006-09-25 12:28:32.001 Host has not answered for 15 seconds. . 2006-09-25 12:28:32.001 . 2006-09-25 12:28:32.001 Wait for another 15 seconds? Pressing 'Abort' button will close session. () . 2006-09-25 12:28:38.361 Attempt to close connection due to fatal exception: * 2006-09-25 12:28:38.361 Terminated by user. . 2006-09-25 12:28:38.361 Closing connection. * 2006-09-25 12:28:38.361 (ESshFatal) Terminated by user.
sudoers looks like so:
myusername ALL=NOPASSWD: ALL
sudo su.
Stumped.
Site Admin -
You cannot use
sudo from terminal. You need to specify it as "Shell" for the session. Please read the FAQ again.
- Guest
My apologies @martin. That worked flawlessly. Thank you.
WinSCP is a great tool b/t/w, thanks for the generous contribution.
- Gogowitsch
- 1
- Dresden
And now for file listings as root
This thread is about the Terminal window (
Let's talk about the core function of WinSCP instead:
I also needed access to directories like
Ctrl+T).
/root and /var/lib/mysql. After some tinkering with the settings I figured out that for Debian and Ubuntu, I have to open the Login > Advanced window, navigate to the SFTP tree item and type sudo /usr/lib/openssh/sftp-server in the SFTP server box. This allowed me to use my non-root credentials to gain root access.
Gest
Im running Ubuntu 17.04. When you make a new session select SCP protocol and click on Advanced Settings. Then select SCP/Shell and write:
On the server I have openssh installed.
I have my user, e.g.:
And I had to add to
So after hours of trying it finally works...
/bin/bash -c "sudo -s"
webdev added to the sudo group
And I had to add to
/etc/sudoers the line:
webdev ALL = NOPASSWD : ALL
schuess
thanks that worked
@Gest: Thanks a lot. Got it to work. The FAQ was not that specific...
Vasiliy
this instructions worked for me (CentOS 7)
This instructions worked for me
https://web.archive.org/web/20221204182956/https://oitibs.com/allow-root-winscp-file-transfer/
The command in my case was:
and in Advanced settings of SFTP:
echo -e "MyUserName ALL=(ALL) NOPASSWD: /usr/libexec/openssh/sftp-server" > /etc/sudoers.d/winscp
sudo /usr/libexec/openssh/sftp-serverAdvertisement
mfiros
set the correct file ownership and permissions:
sudo chown -Rf ec2-user /var/www/mysite/location sudo chmod -Rf 755 /var/www/mysite/location
charlwillia6
Re: thanks that worked
@schuess: Thanks for this. I didn't see that it had to be SCP. This helped.
Site Admin -
@charlwillia6: It does not have to be SCP. It works for SFTP too, but the settings are different. Please read the FAQ:
https://winscp.net/eng/docs/faq_su#sudo
