sincronicing remote mode with delete sincrdeletes local file
anp
First of all, thanks, it is a great utility.
When sincronizing in remote directory mode, whith delete sincronize option, files not in the remote directory are deleted from the local directory. I think they should be copied to the remote dirctory instead. Also, the documentation indicates that remote directory mode only modifies the remote directory.
Re: sincronicing remote mode with delete sincrdeletes local
Sorry, I forgot
WINSCP Version 3.8.2 (Build 330)
Protocol SFTP (allow SCO Callback))
When sincronizing in remote directory mode, whith delete sincronize option, files not in the remote directory are deleted from the local directory. I think they should be copied to the remote dirctory instead. Also, the documentation indicates that remote directory mode only modifies the remote directory.[/quote]
Please post a log file showing that. Preferably such case, where the only synchronization action performed is deletion of one remote file.
