Automatic transfer log in each local upload directory
I've been using WS_FTP Professional since 2007. I recently tried WinSCP and particularly appreciate the superior readability of its file lists.
However, WS_FTP has a feature that I find extremely useful and haven't been able to duplicate in WinSCP.
WS_FTP can automatically write a transfer log to the local source directory after uploading files. By sorting my local file list by modification date, the log file provides an immediate visual dividing line between files modified before and after my last upload.
I maintain a website with numerous directories. A typical work session involves uploading a few files from each of several different directories. As soon as I enter a directory, I can see which files have been modified since my last upload.
I've tried WinSCP's Compare Directories feature. While useful, it requires initiating a comparison and waiting for the results in each directory. My existing method requires no additional interaction or processing delay.
I would like to request an optional feature that:
For example, here are two entries from an actual WS_FTP transfer log:
This feature would allow me to see at a glance which files have been modified since my last upload and review which files I uploaded during the most recent transfer, without requiring comparisons, synchronization, scripts, or additional user interaction.
Is there an existing way to accomplish this in WinSCP? If not, would you consider adding this capability?
Thanks!
- Automatically creates or updates a transfer log in the local source directory after successful uploads.
- Maintains a separate log in each directory.
- Updates the log only as a result of successful uploads, not directory browsing, connecting, or downloading.
2026.10.15 09:03 A j:\Gib\archive\arizona\az1\index.htm --> {deleted full path}/az1/index.htm
2026.10.15 09:03 B j:\Gib\archive\arizona\az1\1949 04 P0008 ai.jpg --> {deleted full path}/1949 04 P0008 ai.jpgIs there an existing way to accomplish this in WinSCP? If not, would you consider adding this capability?
Thanks!
