problems according to console-mode
Barbel Brummel
Dear Support-Team,
I'm using the following batch.cmd
D:\Programme\0-tools\WinSCP\WinSCP3\winscp3.exe /console sftp://root@xxx:xxx /script=D:\Programme\0-tools\WinSCP\WinSCP3\down\download.txt /privatekey=D:\Programme\0-tools\Putty\key\id_dsa_prv.ppk
This code worked fine with release 3.8.1.
Just after I updated WinSCP to 3.8.2 the script doesn't work.
The windows of WinSCP pops up correctly, but after the passphrase of my key-file doesn't start the script (download.txt)...
Screenshot (<invalid hyperlink removed by admin>)
If you need more input, just say...
Greetings,
Barbel Brummel
Re: problems according to console-mode
You cannot specify both protocol (sftp) and /script parameters on command-line simultaneously anymore. It's for security reasons. As SFTP is default protocol, you can just remove the sftp:// prefix.
