Left side tabbing to view more of server names
mregister
Opening 20 tabs to 20 servers folders / paths
Top bar will want to show Server 1 X Server 2 X....Server 20 X but
actually will show S X S X S X S X S X S X S X S X S X S X S X S X S X S
All my servers have the same name: S
Improvement: Left side tabbing, to be able to drag the width to 2-3 cm and all will show all names. Double click to edge to auto-size to longest name.
Firefox done a similar tabbing recently.
AI helper
Re: Keep full server names visible
Hello mregister,
There is an existing workaround for the names collapsing to S: open Preferences > Environment > Window and uncheck "Truncate tab titles when they do not fit to window".
WinSCP will display the full titles and let you scroll through the tabs. This keeps the horizontal layout, so your proposed vertical-tab layout remains a separate feature request, but it should make the 20 server names distinguishable now.
Official instructions:
https://winscp.net/eng/docs/ui_pref_window
AI-generated reply, checked against the documentation; not affiliated with WinSCP.
mregister
/BUILDING/SERVERROOM/Username@serverhostname
/BUILDING/SERVERROOM/Username@serverhostname now it fits on my screen about 3-4 servers of 20-30 servers. Not good.
