PIN for login dialog
ndwbratl@gmail.com
United States
If you're adding a site for accessing a cloud location with an unusually long user id or password (or God forbid an S3 Access key ID and Secret access key!), I would think a PIN required to use the site definition would be helpful instead of leaving out and having to retype the actual password or secret access ky every time. If a user is on your PC and wanders into WinSCP, you don't want them accessing a site just by clicking the site defintion...
ndwbratl@gmail.com
Re: PIN for login dialog
Thanks, Sorry for the stupid question; I found that answer after reading more doc. I'm relatively new to WinSCP – it's an amazing product and very well documented. I already have batch scripting working.
Thanks!
Nick
