The timestamp function is not available
Wei
Although I set the timestamp function, I failed to get a timestamp tracking on context (The folder) I also tried Synchronize ,but it doesn't work.
  • 螢幕擷取畫面 2026-10-11 125638.png (76.86 KB, Private file)
Description: This show that I've coorectly set the timestamp transfer.
  • 螢幕擷取畫面 2026-10-11 125619.png (40.21 KB, Private file)
Description: The box turns gray and said that all the setting for transfer files can't use.
Re: The timestamp function is not available
Preserving timestamps is not available with all protocols and servers. For details, see:
https://winscp.net/eng/docs/ui_transfer_custom#common
https://winscp.net/eng/docs/protocols#timestamp
If you need further help, please specify what protocol are you using and attach a full session log file showing the problem (using the latest version of WinSCP).
Wei
The attached file is the log file generated during the SFTP file transfer.
The context option in the gray box is still not working. Directory timestamps cannot be preserved, although file timestamps can be preserved.
  • TWNI3-login_.txt (1.9 MB, Private file)
You are using SCP protocol. While you have possibly selected SFTP (I cannot tell as you didn't post a complete log file), the server rejects SFTP session. So WinSCP falls back to SCP protocol. With the SCP protocol, preserving directory timestamps is not supported.
. 2026-10-16 16:53:22.439 [Background 1] Opening main session channel
. 2026-10-16 16:53:22.556 [Background 1] Opened main channel
. 2026-10-16 16:53:22.561 [Background 1] Primary command failed; attempting fallback
. 2026-10-16 16:53:22.568 [Background 1] Started a shell/command
. 2026-10-16 16:53:22.568 [Background 1] --------------------------------------------------------------------------
. 2026-10-16 16:53:22.568 [Background 1] Using SCP protocol.
