Important local folder disappeared after WinSCP transfer and deletion
martina
I need urgent help because I may have accidentally deleted an important folder containing about one month of data.
I am using WinSCP on Windows 11 Pro.
The folder was originally on my local Windows Desktop. I dragged the entire folder from the left panel (local computer) to the right panel (remote server) to transfer it to the remote computer.
After the transfer, I realized that I had put the folder in the wrong location on the remote server. I then selected the folder in the right panel and used the delete/trash option.
The problem is that the original folder has now also disappeared from my local Desktop. I cannot find it anywhere on the computer, including the Windows Recycle Bin, and a Windows search for the folder name finds nothing.
I am worried that I may have accidentally moved the folder back to the left/local panel and then deleted it, but I don't remember doing this.
The WinSCP Recycle Bin option was NOT enabled.
My local drive is an SSD.
Could WinSCP have deleted the original local folder, and is there a way to determine exactly what happened from the WinSCP logs/session history?
The data is very important, so I would like to avoid doing anything that could make recovery more difficult.
Thank you for any help.
Re: Important local folder disappeared after WinSCP transfer and deletion
Did you have the session logging enabled when it happened? It's not enabled by default. If you had it enabled, please post the log.
