Remote Server Not Showing Details
dan15237
Pittsburgh PA
We are trying out SCP and have found an issue we can't explain. We are moving files from a remote server to a local computer and also from the local computer to the remote server. When first using SCP after installing all works as expected. Subsequent uses do NOT show the file details on the remote server which in our use case is relatively critical. The file details show on the local computer as expected. Screenshot is attached showing local and remote. Is there a setting that is changing the behavior of the remote server not allowing the details to show?
Description: Screenshot.
Re: Remote Server Not Showing Details
dan15237
Pittsburgh PA
Attached.
  • MMS-FTP.log (19.77 KB, Private file)
Description: Log file.
