Certificate Errors
Alan
Certificate Errors
I am on Version 6.5.7 of WinSCP. I upgraded after a previous version kept failing to connect.
The error seems to be certificate related. The log is showing this:
[2026-09-30 15:02:09.958] [2398] TLS failure: Certificate not trusted. (8)
[2026-09-30 15:02:09.958] [2398] Hostname: winscp.net, Certificate: XXXXX
[2026-09-30 15:02:09.990] [2398] Error from Windows certificate store: Error: 800B0109 (A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider), Chain index: 0, Element index: -1
[2026-09-30 15:02:09.990] [2398] Root certificate: XXXXX
[2026-09-30 15:02:09.990] [2398] TLS certificate error: Certificate not trusted.
[2026-09-30 15:02:09.990] [2398] HTTP request failed: Certificate not trusted.
Server certificate verification failed: issuer is not trusted
[2026-09-30 15:02:09.990] [2398] Certificate error detected.
I've seen other posts on this forum about this, but not sure what the solution is to get this working?
Re: Certificate Errors
So do I understand right that this is about an error, while WinSCP tries to check for application updates, is that correct?
Alan
Certificate Errors
Hello
Not exactly, I am trying to open an FTP connection to a server, which fails, but it looks like it is also trying to update and failing.
The server in question can be connected to fine with FileZilla.
Thank you
So please post session log file of your FTP connection.
