Inconsistent download URLs for RC releases
I've installed WinSCP using Scoop. Current version is 6.5.7. However I want to test latest beta, 6.6.3.RC, to sign in using OpenSSH ssh-agent. Scoop has a nice feature to auto-generate manifests for any version, but it won't work with RC versions.
> scoop install winscp@6.6.3.RC
INFO  Resolving historical manifest for 'winscp' (6.6.3.RC)
WARN  No historical manifest found for 'winscp@6.6.3.RC'; attempting autoupdate
Autoupdating winscp
Searching hash for WinSCP-6.6.3.RC-Portable.zip in https://winscp.net/download/WinSCP-6.6.3.RC-ReadMe.txt
Found: 10df2b9191641b321d5e0ab58dcaac8042cf92ace19a7ef8ffe35ac196a100ea using Extract Mode
Writing updated winscp manifest
Installing 'winscp' (6.6.3.RC) [64bit] from generated manifest
The remote server returned an error: (404) Not Found.
ERROR URL https://downloads.sourceforge.net/project/winscp/WinSCP/6.6.3.RC/WinSCP-6.6.3.RC-Portable.zip is not valid
Indeed, the proper URL is https://downloads.sourceforge.net/project/winscp/WinSCP/6.6.3 RC/WinSCP-6.6.3.RC-Portable.zip, i.e. the release folder is named with a space before RC instead of a dot.
Could the folder name be the actual release version, only with dots and without space? I believe it will be useful for other automation software as well.
Re: Inconsistent download URLs for RC releases
Thanks for your suggestion. We will see if more people ask for it. It's not a trivial change to our deployment process.
